johnjk
Apr 13, 2017
1,685
1,860
West Mansfield, OH
You must not have the crankshaft driven FEL pump. Lucky!
Nope. It would have taken me a bit longer if I had the FEL pump. A few more things to loosen and remove. Hardest part was snaking the belt around the fan blades and the shroud. She is pretty basic, 4wd, hst, mmm, and 3 point out back.
Ping
BX2370-1
Dec 25, 2018
335
300
Troy, Ohio
Unloaded my birthday present from the wife. She said she hopes I'm worth it:unsure:
I think I done well on both counts.
Regards,
Reactions: 6 users
Weasel1
Kubota L2501DT, Land Pride Rotary cutter, Kubota bucket
Jun 28, 2020
35
35
East Tennessee
Used the new tractor and LandPride rotary cutter to cut down 5 acres of horse pasture. Worked great.
PapaJ
L2501 HST
Apr 28, 2020
284
107
TX
Hit 20 hours while mowing, then figured out no matter how much water you use, it's not possible to get the MMM deck clean while it's on the tractor.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,526
3,712
PEI Canada
Mowed the lawn. It was hot and humid outside and nice and cool in the cab.
Magicman
Oct 8, 2019
6,050
9,481
Brookhaven, MS
knotholesawmill.com
Back to the farm to do some welding on the disc before it is needed this Fall.
Lift the disc frame up off of the disc assembly.
Steady as she goes.
Grind and bevel the broken parts.
'Bout ready for welding.
I believe that will hold.
Reassembled and ready for action. Thank You Kubota FEL.
BigG
Sep 14, 2018
1,951
774
West Central,FL
Just me but I would not wash off the mower. Use a leaf blower or compressed air instead. The wet grass that you can not get off, and there will be some somewhere, will start the rusting of the new machine.
dlsmith
BX2230, LA211
Nov 15, 2018
1,299
909
Goshen, IN
I always use compressed air with a three foot long nozzle with a 45° bend on the end to blow off all the clippings. I also take the covers off the belt drive and blow the clippings out of there, and clean off the battery cover also.
FreezinGator
BX1500 LA181 FEL 48MMM Back blade
Jul 10, 2020
58
Upstate NY
I changed the oil on my BX1500 and replaced the drain bolt with a ValvoMax drain valve. The previous owner had damaged some threads on the pan and the drain bolt would not torque down. I repaired the bad threads by gently running a tap thru it and the drain valve torqued fine. The drain valve is tucked in behind a frame cross brace and just under some hydraulic lines so I am not worried about it hanging up on anything under the tractor. It also has a cap/o-ring on it if the valve itself ever leaks. Going to make it easy and clean for future oil changes also.
Magicman
Oct 8, 2019
6,050
9,481
Brookhaven, MS
knotholesawmill.com
I use this for blowing the grass clippings from the mower deck as well as the sawdust from the sawmill. Yes it's new, and just replaced the BG55 which now has duties at the farm blowing off the Bushhog deck.
MFFI422
BX2380 -Drive Over Mower Deck- LP Tiller - FEL - LP Box Blade - LP QH - Canopy
Jun 10, 2020
81
35
Arkansas
I'm fixing to kill everything that's green on the property. lol. Eraser is on the job!
Magicman
Oct 8, 2019
6,050
9,481
Brookhaven, MS
knotholesawmill.com
I only have ~25 acres that are not timbered so bushhogging is not a real chore, just something that has to be done. My main problem is Sweetgum and Persimmon sprouts that have to get a dose of 2-4D to keep under control. I hates Sweetgum!! :( Matter of fact, I even have a plaque to prove it:
michigander
547
234
Northern Michigan
Wife suggested a canopy for the B2601. with P.O. approved I ordered a Curtis Canopy from Artillian.
TTWT code saved $50.00 and code works on orange color. :)
7,072
For almost 25 years I thought I had no use for a leaf blower.....
A couple times I’ve even used it for leaves!👍
Magicman
Oct 8, 2019
6,050
9,481
Brookhaven, MS
knotholesawmill.com
Hey that is one of the newer ones. There were several improvements from the "5's" to the "6's". I think that I will like the newer choke arrangement better, time will tell.
NWAZL3560
L3560, LA805 loader, BH77 backhoe, rock bucket, box blade, pallet forks
Jun 11, 2018
128
58
Mesquite, NV
I've been working on taking out an RV sewer line since we've changed our mind on the RV location. Here in NW AZ the working hours are 4:30 - 6:30 a.m. these days. Caught a nice picture yesterday as the sun was just beginning to rise. I love having the back hoe on call and being able to use it for an hour or two and then continue the next day and the next.....
3,216
Cool pic!
Just curious, why say NW AZ if you are from SE NV? (Mesquite Nevada)
Inquiring minds want to know.:)
