Hi guys. I need your help. I have a L245dt with no PS, my FEL is driven off a crankshaft pump and it and it's resevor are completely separate from the rear hydraulics. The rear hydraulics have all steel lines. The rear hydraulics operate extremely slow and only at hi rpm. I have drained the fluid cleaned the tubular filter twice and made sure it is seated properly. It does however have a very, very,very small wrinkle in it. I have cleaned the pressure relief valve and have played with adding shims. My first question would be how do you install a test gauge into the system? I removed the plug (#34 in the O/P Cover assy) drilled and taped it to except a 3000 lb pressure gauge thinking that the cover might be where pressure readings are taken. Gauge read 0. Installed second gauge still 0. I have removed the Hyd pump and can feel pressure and suction when rotating it in the proper direction. I applied air pressure to the steel pressure line and fluid flows out the return line. I have removed and cleaned the vent tube. As of yet I have not removed the lift arms and cover. I believe that is where the control valve is. Nor have I torn the pump apart yet. Again, this tractor does not have power steering so there is no priority valve in the system. Any ideas and where do you take pressure readings at and how is a gauge installed?
Thanks . BB
Thanks . BB
