As I said ' I did a pressure reading at the pump and the pump works just fine . With my control valve I put on my pressure gauge I was able to crank it down and saw 2000 lb. Hose from the control valve dumped directly into crank case. There is no problem with flow from the pump. I've opened up the rear of the tractor and dismantled the control valve except for the valve under the slotted plug. I'm having trouble removing slotted plug from body. My Drag Link socket on a breaker bar has too much slop and I don't want to bugger up the slot. Asking if there are any tips or tricks. If not I'll machine a tool.Sounds like you're not getting any flow out of the pump.
Crack a pressure line and see if you get fluid out of it, if you don't you aren't getting any flow.
Thanks BB
