https://soltron-gtr.com/Google searches dont give up too much info on soltron.loves "star tron" though...almost no links to marketing not even a link to NAPA... dang. Best kept secret
yes...but other then "NAPA" where are the retailers selling it ? usually there are many options ( amazon- wallyworld-advance ect)
Want to know a little secret about Soltron? Read the below attachment from the soltron FAQ page.I can say it works incredibly well, the marine industry uses it because all the moisture issues in their fuel systems.
I think one reason that you don't find it everywhere is that it's expensive, too much risk for wally world and the such kind of places.
There are three similar product, starbrite, startron and Soltron, I've never use the other 2 and they might work the same (I think one is specifically for gasoline) but I don't want to change considering I've had excellent result from Soltron.
Citation please ?Want to know a little secret about Soltron? Read the below attachment from the soltron FAQ page.
He's right it's right on their internet site:Citation please ?
Im more concerned for my HPCR Cummins and Kubota Diesels where Bio's can hurt injectors. Clean fuel is the key to smooth HPCR's. Anybody have any experience with the Cat fuel filter add on for Diesels on Kubotas ?I have to sat I tried the Startron and it didn't do squat for my gas engines so I went back to Seafoam.
And some engines do not get warm enough.....I am going round and round with the dealer right now on my new L3901 that runs forever and doesn't get warm enough. I covered the radiator up halfway which did bring the temp up a little but finally threw a wool blanket over the intakes on the cowl and the temp came up high enough to regen......should not have to do that.A cold engine will not regenerate. It has to be hot. Bernhardline is correct on most points but I would suggest full throttle instead of just 2000-2100. Just push the lever all the way forward and let it eat. It will not hurt anything.
I tried that step yesterday. Auto regen while stationary. Cranked the rpm up to about 2700 to get the rpm light to go off. Regen light still flashing after 20 minutes. Tractor was warmed up prior to this due to working. Auto regen failed, then parking regen light in dash started flashing. Got manual. Verified steps.1-->5 and 7. Hit inhibit switch (on), then again, off. Lamps still flashing. Eventually after some iterations I can't remember, the inhibit and parked regen switches started flashing. Getting somewhere finally. Hit inhibit, switch light off and parked regen (switch light stays on). Then successful parked regen including automatic rpm increase/decrease.Did anyone drive tractor when you were recovering? It is odd that the tractor would suddenly jump to needing a parked regen when you start it.
The automatic switching of the lights and the beginning of a regen won't happen until the tractor is warmed up... may require more time.
Tractor appears to be in PM warning level 2-2. Manual claims you can switch to auto regeneration. You don't have to drive it, it can remain stationary, but you do have to run the rpm up.
Do you have the old style regeneration inhibit switch? Does yours have a diagonal slash through it?
If you can't get it to regen, don't drive it!
Good questions and I don't have answers unfortunately. My scenario was almost exactly like yours except I got the red engine warning light and it wouldn't go off. Dealer came by and the tractor wasn't throwing any codes, they gave up then came back on put it on a flatbed and took it back to the dealership. They also thought it was a throttle positioner issue but it was not.....they were lost in my opinion. At the shop they went back to a regen problem and said that the tractor wasn't getting up to temp in order to regen. They drained the cooling system and filled it with straight antifreeze and said that would make it run hotter. A little sceptical on that one and I have always read that running straight antifreeze isn't advisable and how it makes it runner hotter is beyond me. At their direction I blocked the radiator about halfway and that pushed the temp up a little. This weekend I worked it hard and the regen light started blinking along with the light indicating that rpm needed to go up. I popped it up to around 2800rpm until the light went off and let it run. The regen light kept blinking indicating the regeneration hadn't started and I then went and got a wool blanket and covered all the intakes on the cowl. Six or seven minutes later it apparently got warm enough to regen and the regen light went solid. 15 or 20 minutes later the light went out and I assume the regen was completed. This whole ordeal is horse s&*^. No way a new $25,000+ tractor should run like this. There needs to be a fix. I wonder if the engine has a thermostat? This is like buying a new $50-60,000 pickup and having to block the radiator to get the heater to work.....like 50 years ago! I plan on keeping on bitching to the dealer until they come up with something that make sense and works!I tried that step yesterday. Auto regen while stationary. Cranked the rpm up to about 2700 to get the rpm light to go off. Regen light still flashing after 20 minutes. Tractor was warmed up prior to this due to working. Auto regen failed, then parking regen light in dash started flashing. Got manual. Verified steps.1-->5 and 7. Hit inhibit switch (on), then again, off. Lamps still flashing. Eventually after some iterations I can't remember, the inhibit and parked regen switches started flashing. Getting somewhere finally. Hit inhibit, switch light off and parked regen (switch light stays on). Then successful parked regen including automatic rpm increase/decrease.
Questions:
1. Will parked regen only work if you have inhibit activated first?
2. If you try auto regen, stationary, and it is going to fail, do you just wait for the parked regen lamps/switches to start flashing?
Note: Mine is also an L3901. Has about 47 hours.
What was the air temperature? What did you do after upping the rpm? If you go on working it, it is better. Yours is not behaving typically.Good questions and I don't have answers unfortunately. My scenario was almost exactly like yours except I got the red engine warning light and it wouldn't go off. Dealer came by and the tractor wasn't throwing any codes, they gave up then came back on put it on a flatbed and took it back to the dealership. They also thought it was a throttle positioner issue but it was not.....they were lost in my opinion. At the shop they went back to a regen problem and said that the tractor wasn't getting up to temp in order to regen. They drained the cooling system and filled it with straight antifreeze and said that would make it run hotter. A little sceptical on that one and I have always read that running straight antifreeze isn't advisable and how it makes it runner hotter is beyond me. At their direction I blocked the radiator about halfway and that pushed the temp up a little. This weekend I worked it hard and the regen light started blinking along with the light indicating that rpm needed to go up. I popped it up to around 2800rpm until the light went off and let it run. The regen light kept blinking indicating the regeneration hadn't started and I then went and got a wool blanket and covered all the intakes on the cowl. Six or seven minutes later it apparently got warm enough to regen and the regen light went solid. 15 or 20 minutes later the light went out and I assume the regen was completed. This whole ordeal is horse s&*^. No way a new $25,000+ tractor should run like this. There needs to be a fix. I wonder if the engine has a thermostat? This is like buying a new $50-60,000 pickup and having to block the radiator to get the heater to work.....like 50 years ago! I plan on keeping on bitching to the dealer until they come up with something that make sense and works!
Around 60 degrees and yes I kept on working it. I have also been keeping the rpm's up around 2500 as the dealer recommended even though most of my tasks only require 2000.What was the air temperature? What did you do after upping the rpm? If you go on working it, it is better. Yours is not behaving typically.
I find it difficult to believe your engine couldn’t get warm enough at that temp. I wonder if there is a defective temp sensor? See what it does next regen. If not normal complain again to dealer.Around 60 degrees and yes I kept on working it. I have also been keeping the rpm's up around 2500 as the dealer recommended even though most of my tasks only require 2000.
