Kubota B3350SU Discontinued
beex
312
on my bx
Bottom line: when you have 8 billon people eating and shitting everyday, your going to have an environmental problem of some kind.
SDT
multiple and various
Apr 15, 2018
3,376
1,161
SE, IN
I couldn't agree more. I have yet to see one of these talking heads walk the walk. All take and talk, the whole group.
You sir should not drive a truck! - While I own 10 cars, a private plane and maid in my 12,000ft house with the 1 acre pool.
My neighbor drives a prius and keeps the heat at 72 all winter and AC at 70 all summer??? She lectures me about owning a diesel truck and doesn't even understand her AC and heat use are environmental factors. She is as dumb as a box of rocks except about this, when it comes to complaining about other people and the environment, she is the smartest person in her house.
Personally I think America is ahead of the pollution curve and should continue to improve.
Well said.
SDT
vanquisher
B3350
Sep 21, 2018
26
Lagrangeville NY
i have made the point a few times on this page and it really seems to be overlooked and or ignored. How many 3350 units has Kubota sold? How many complaints on the net have you seen from different people. I have seen many post with different issues other then DPF but dPF gets blamed. Treadle pedal safety switch, water in fuel to name two that come to mind. The unfortunate thing is the title of the post reads 3350 dpf something or another and that is not the case. I am just as guilty, anything goes wrong I think oh no the dPF but it's not the issue. I feel for anyone that has had problems and I also worry about mine. The seed has been planted and unfortunatly its gotten two black eyes. I feel this is a really nice machine and I wouldn't want the 2650 and have been told by a few dealers that the issues have been solved. I have also been told with all the updates there still is a lot of operator error or misunderstanding..Future will tell.
SDT
Apr 15, 2018
3,376
1,161
SE, IN
True, but the overwhelming number of issues with the 3350 are regen related.
Yes, Kubota does blame some such issues on "operator error," but this is a red herring, especially when the operators manual and DPF decals are inaccurate.
BTDT.
SDT
tempforce
B2650HSDC
Jun 23, 2012
387
bastrop, tx
My Kubota has 560 hours and have only had one problem with regeneration. All the updates have been preformed by the dealer. I think most of the problems with the B3350SU is not running them at high enough RPM. I run my tractor above 2000 RPM and never let it idle during use.
I ran mine at full rpm... still had all sorts of regeneration issues. dealt with it for a year, before buy back. out of the year I had a total of 42 days of use... I averaged over 80 hrs a month with the L3300 I traded in. my 2650 averages about 50 as most of the work is finally getting completed... I'm a year behind schedule due to the b3350. the b3350 had the following replaced. computer, alternator, exhaust filter, wiring harness. had 6 service calls and 5 trips to dealership for repairs... not sure I would buy another Kubota, I bought Kubota this time, due to buyback and all of the attachments wouldn't fit brand x machines...
KHW59
L-3901 Brushhog, Finish mower, road planner, box blade.
Apr 28, 2016
59
Palatka Fl
Some here are aware of my trials and tribulations with my 3350. As a former Submarine Missile Technician, its engrained into me to follow directions. When I got the 3350 I read through the manual several times and had a PDF of it on my phone. (Call it anal-retentive, 30 years of doing that just makes it normal) The 3350 was just poorly engineered for regen. My normal operating RPM was 2300 and I let it warm up prior to use.
Regen occurred like clockwork at 12 to 15 hours between events. The first failure was around 70 hours with it shutting down during the regen operating at 2200 RPM and not being able to restart until 30 minutes later to finish the regen parked. This got worse until I traded to the L3901 at almost 800 hours. I have 105 hours on the "L" with at regen at 35 and 101 hours. The regen on the L is quite a different cycle than the B. I liked the 3350 as it was a workhorse at the ballfields I helped maintain. When it was running:p
shootem604
Apr 23, 2018
874
British Columbia
Anyone offering "delete" kits? That seems like a nice out of warranty fix for what could be a cheap used tractor to pickup...
SDT
Apr 15, 2018
3,376
1,161
SE, IN
Not in the US.
Who knows about other countries..
SDT
MadMax31
BX23S, 60" MMM
Nov 5, 2014
763
New York
Their was a guy in the classifieds looking to do this. Not sure if he had it figured out, or was looking for guinea pigs?
powersrp
B3350
Apr 2, 2017
94
Indian River MI
a cheap used tractor? i wouldnt sell mine for $40,000. Kabota got tier 4 jammed down its throat after the tractor was already designed, they did not have time to make it dummy proof out of the gate. 5 yrs, 650 hrs and not a hiccup, this tractor punches above its weight class. Yes the manual can be confusing, dont need it, the tractor tells you when the light comes on it needs to clean out, 2200 rpm and walk away, how friggin hard is that.
9,772
Like the other ranting post that you put up.
I'm glad you feel so highly about your tractor, hope you never have issues with it!
Issues with this model are not always operator error, far from it.
Like I said before, take a breather, no need to insult or defame anyone that's had or having issues with their unit!
3,703
Good Works Tractors has a video pointing out the 5 WORST tractors on the market and the B3350 is the first in his DO NOT BUY list. (The orange thing in the background is one of the BEST in his opinion, a B2650, little brother to the awful B3350. You can skip the intro if you wish... start at 2:00 mins into the vid:
5,506
2,213
it didn't have tier4 jammed down it's throat. The EPA don't give a rat's backside how the emissions are reduces, all they care is that they are reduced.
At that (and this) time the least invasive method is the DPF, and on 75hp+, DEF with DPF.
Trust me, if it could be done any better way, it woulda already been done. Kubota didn't want it, neither did anyone else. But they had to meet a standard that the government set forth, and the way they chose to do it was the least invasive from many points.
While I do agree that the reformer system is inherently flawed, most of the time if the operator understands how the system works, it just works. Unfortunately, educating owners has and still does leave a LOT to be desired. Salespeople are in a hurry to go sell more stuff and they don't spend enough time with owners and their new equipment. At some point it catches up, as it did with the place I used to work for.
If you guys had the training available to you as I did for me when I got "familiarized" with the reformer system, you'd better understand and respect it, which leads you to a mostly trouble free life with it.
Why a reformer? Because a common rail engine designated for dpf was so small and so much more expensive, that it wouldn't properly work with the dpf, and put it into a price range that wouldn't compete with other brands. The reformer was added. Basically it's a retrofit to a then-currently available V1505T.
Now that "they" know a lot more about DPF's and common rail, and they also have more sources for parts, they can actually do this correctly, once and for all. It's been in testing for several YEARS but they did NOT want to just send something out to the masses like they did with the B3350 and ZD1511 (same engine). By the way, argue all you want but they ARE the same engine (I had one of each). Cut little baby turbo on both of them, on the 3350 the turbo is buried and you can't hardly see it, the 1511 it's not covered up as much.
So why not just add a dpf to an already existing engine? Because a dpf has to run at a certain temperature in order to passively regenerate (in the background as you work) without needing excessive extra fuel added, of many other things. On a turbo engine, the turbo cools the exhaust temp before it reaches the dpf. How do you heat it back up? Blow air and fuel into the exhaust stream. This requires sensors, wiring, a blower, an injector, lines, pump, hoses, and a bunch of other stuff--aka "reformer" system. 3350 is a smooth running 4 cylinder with a small 1.5L displacement, turbocharged. The engine was used because it was already available, just modified to work. Common rail? Adjust injection timing and quantity elecronically. Much easier much cheaper makes more torque maintains rpm much better runs quieter simpler easier to service fewer parts etc in comparison to reformer system. And-with common rail, in a very simple way of describing it (on a diesel) you can take an existing larger engine and adjust the fueling way down so that it will make less power, or you can take a little bitty engine and throw the coal to it and make the same power, both ways are relatively easy with electronic control of the injection keeping in mind that they also have government standards to meet. That means piston shape become critical, compression ratios, induction, exhaust, a ton of things all play into it.
it's a fine line between doing what consumers want and doing what the government wants! Sometimes the outcome is a black sheep, which is what we had with the 3350. Hated by many loved by a few (one?) and Kubota is...FULLY aware of it's issues. They were aware of potential issues the day it was OK'd for production.
3,703
Lugbolt, that’s an informative way to throw oil on the whitecaps.... but it remains that Kubota produced a troublesome model and is paying the price in injured reputation over it. It’s easy to just blame the gub’mint ... but every mfr’r had the same reg to meet.
Steve Neul
B5200
Jun 3, 2017
130
14
Terrell, TX
That's why I stick to old equipment. I have one tractor made in 1959 and a Kubota made in 1987. My newest car is made in 1993. The greenies are going to kill us all.
3,703
Anyone who lived in or visited Los Angeles in the 1970’s.... and have gone back since.... will not agree.
I’ll never forget coming over-the-hill on I-10 in 1979 and seeing that city below the brown-smog-level that was simply choking.... versus now and how clear the skies are and how much public health (which we all pay for one way or the other) has been improved.
3,703
Oh please. Look at your machine list. Do you really need all that?
If you were really worried, like Al Gore, you would walk the walk and not simply talk the talk. You could easily replace all of your machines with a team of draft horses and donkey with a cart. It is for our kids after all..
You don’t know me.....You only think you do.
SDT
Apr 15, 2018
3,376
1,161
SE, IN
That is a rather specious argument.
Nearly all of the needed improvements vis a vis air pollution were made decades ago yet the federales never stop and have been imposing increasingly ineffective and expensive mandates for additional decades.
Have you ever heard of a governmental agency saying "Our mission has been accomplished and it's time to dissolve?"
Federales must continue to make our lives more and more miserable in order to justify their existance.
SDT
3,703
SDT
Specious? Have you considered the huge INcrease in numbers of vehicles and population since the late ‘70’s... And YET...the air is cleaner?... the water is cleaner... Less mercury in your diet...?
If the EPA were abolished... what do you think would occur? EPA was signed into law by Richard Nixon but the man who’s been in office less than 2 months is to blame for emissions enforcement according to some. :rolleyes:
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,062
1,509
Pittsburgh
Horses and delightful nanny goats are not viable alternatives because they fart.
