L3710 bucket cylinder has cracked gland.
dmcb
11
Inverness, Florida
The tilt cylinder (LA682 loader) has a cracked gland. None are available and I must buy the entire cylinder for over $650. I believe both lift and bucket cylinders use the same gland.
I am hoping someone there has a scrap cylinder that might have a good gland. I sure would appreciate any suggestions.
Thanks.
The gland is the threaded piece that the shaft runs thru that goes on the end of the cylinder.
200mph
Mar 3, 2017
1,228
61
PA
I'd investigate having a local machine shop making new if you can't find used.
SidecarFlip
Banned
555
I would imagine that any competent hydraulic repair shop can rebuild it for a lot less.
dmcb
11
Inverness, Florida
I had it to the best hydraulic repair shop around here. There is a hairline crack from the center hole thru the threads. That makes brazing or welding difficult.
I am sure there are cylinders around that have been damaged but the gland is still good. The problem, finding it.
5,564
Might send a PM to "007Kubotaguy" on this forum. He has parts of older L tractors and maybe you'll luck out.
I'd think just about any machine shop could make the gland at much less cost then a new cylinder.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
Wonder what's so special about the gland? I had to replace one on my Kuhn mower 2 years ago and the shop I use had one on the shelf. They rebuilt the cylinder and replaced the gland for like $80. I was very happy with that.
dmcb
11
Inverness, Florida
I would be happy also but he part is obsolete and no longer available. I cannot find a part number for it to see if someone had one on the shelf. I made an expensive mistake here. In looking for the part number for the cylinder I came across a number that said replaced by xxxxxx part which was the cylinder. I then looked for the old part number, found one for a good price. It was just the shaft which I have and is good. So unless they will take it back this cylinder iw going to cost over $1000. That is why I am hoping for a used gland from somewhere. Or even a new one. It may fit several models but I have no way of knowing.
5,564
I'm not sure, but I think you're referring to the bucket cylinder.
You can go to Kubota Tractor Corp website and enter you model tractor and then the loader and get all the part numbers. It appears to me you need part number 75554-64410, which they call the "head".
Messicks shows it for $130. https://www.messicks.com/part/75554-64410/head-1
Don't take my word for it, call Messicks and talk to parts and then order what they suggest.
dmcb
11
Inverness, Florida
I thank you for your research. I will grab it for sure but I am waiting for a response to return the wrong part I ordered. I also ask them about the part I need and I want to be sure they do not have it. They don't respond quickly so I have reservations about returning it. We'll see. Thanks again I really appreciate it.
dmcb
11
Inverness, Florida
I was able to return the part. Going to cost about $80 but its better than eating he part.
The part was the correct one and it is on order.
Thank you again. You saved me a lot of money and I appreciate it.
Doug
dmcb
11
Inverness, Florida
Well talk about being run up and down the emotional scale. just got an email saying they no longer have this part and there is no sub.
Back to the drawing board. Gonna try the burned tractor.
Doug
3,316
Are you sure a good welder can’t fix that thing? Stitch it, then finish?
BAP
Dec 31, 2012
2,745
858
I would find a different hydraulic shop. One that has the ability to make and machine parts. The ones that do that can also build cylinders from scratch to fit the applications.
5,564
Did you try 0007Kubotaguy? He could very well have a damaged cylinder.
You can go to this post. Go down to the second comment, see his name in the upper left corner. Click on it and an option will be to send a PM. Click that and then send him a question of what you need. https://www.orangetractortalks.com/forums/showthread.php?t=39025
