Yea, though it is just a root rake, not a full on grapple. I dont have a 3rd function valve. Its about the same weight as the bucket - they are just a few pounds difference. I have thought that I could run the bucket and take a scoop of dirt and ride around with it when using the harrow for even more weight. After using the harrow though this weekend I don't think that will be necessary. I didnt have any problems pulling it at the most aggressive angles with 4wd engaged, and in a well tilled area. That was the worst case scenario test for me. I don't plan to hardly ever use this disc harrow in these most aggressive angles - Its really aggressive, and does put the tractor under some strain, you can feel, for example turning you can feel it fighting to turn and the turn radius is wider. I find in the middle settings it has a similar outcome on the ground, but pulls a lot easier. I am in North FL/South GA so its really sandy soil, very fast leeching, no clay or anything, so its an easy ground to break. Just a few passes and you have loose powder that just sinks below your feet.
