Has anyone used the Titan 46 inch pallet forks that are a fixed mount. They seem to be the economy model for $299. Looking for a set of forks for L2501. Thanks!
You have already pick up on the problem with that style of fork.Thanks Mainah, Any issues with the clamp on style bending the bucket? I was looking at those as an option to. My goal is to be moving trees to a sawmill over some rough terrain and i was thinking the bouncing my cause some deflection in the clamp on style forks.
No, but I’m careful about what I lift with them. I unloaded a 4” pto chipper, about 650 lbs, and a 500 lb stove and that’s as far as I’ll go with them. The chipper made the rear wheels light even with my 64” snowblower on for ballast and that didn’t bend anything. Narrow pallets are the only reason I used them in both cases. The bigger issue with these is keeping them from moving with weight on them. You need to hammer the screws tight and put a ratchet strap on them if you can’t use the stabilizer bar between them and I couldn’t in either case because the pallets were too narrow.Thanks Mainah, Any issues with the clamp on style bending the bucket? I was looking at those as an option to. My goal is to be moving trees to a sawmill over some rough terrain and i was thinking the bouncing my cause some deflection in the clamp on style forks.
the Titan made in USA 48" forks with the headache rack are about $550 deliveredI bought these 36" Titan brand forks last month. They weigh 300lbs and are built pretty stout. Cost $454 that included shipping, they arrived 7 days later. Noticed they increased the price to $504 recently.
Railroad cross ties weigh about 200lbs each and the 2501 lifted everything with no problem.
That's a nice set of forks and the price was even better!I got these 42” quick attach 2500 lb lift capacity from Pro Works for $449.
This my temporary solution until I decide exactly what type of welded guard to have fabricated. Only owned the tractor about a month.Hey there Inthepines do I see a mod to your front grill guard? Looks like some sort of mesh wire covering. Could you elaborate as to why and what it is?
Thanks
