How long did your original battery last?
bambam31
L3800HST 4x4,R1,FEL, 6'disc, 5'bush hog,piranhaTB,6'grader,6'rake, 48"forks
Apr 3, 2014
321
27
23
Mobile, AL
I purchased my L3800 new in 2014. It's still cranking fine on the original battery but I've been wondering if I should just go ahead and replace it.
Saxman
L3830 ZD21
Jun 19, 2010
155
Mt. Vernon, IL
I purchased a new L3830HST new in June of 2006. It currently has +/- 725 hours and still has the original battery!
2,831
I would not replace it.....until it decides to slow down a bit....and you will know when it does btw;):)
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
My 2012 L4600 still as original battery in it, just came a check on the water level and keep terminals clean.
When she starts slowing down when cranking I'll replace but till then.
bearbait
Dec 9, 2011
4,104
879
New Glasgow Canada
This tractors start so easy I don't believe their very hard on a battery. I keep a trickle charger on mine whenever I'm not using it.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
My 2013 l3200 still has original battery and still cranks fine,the original owner bought it in 13,worked overseas,tractor had 12 hrs when I bought the house in 2016,cranked right up after sitting.btw bambam,hope you don’t have to use yours for storm clean up this week,I’m getting ready here,luckily they keep moving the path further east of us
5,309
my old BX23 (2006) was still cranking just fine on the original battery when I traded it last year. I always had it connected to a battery tender jr.
Smokeless
3901/Loader/Rear Blade/Box Blade/LP Mower/Pallet forks IH M,,Cub & sickle mower
Feb 5, 2018
237
9
Southern Illinois
That exactly what I plan to do with my 3901, use a battery tender. My father had great success extending battery life with a tender.
Pleased to hear so many batteries lasted so long.
5,309
Other than on road vehicles, I use the battery tender jr's on all of my stuff, quads, mowers, boat and tractor.
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
76
Rocky Face, Georgia
I got 11 years out of the battery on my L3000 but it's used almost daily. But when it died, I mean it died.
I'm on my third in my 04 M9000 but it sits most of the winter.
6,876
I’m on year 5 with my BX, jeepers why did I say that.....[emoji12]
I keep it on a tender when not in use much and most of the winter.
I do use it year around.
bambam31
Apr 3, 2014
321
27
23
Mobile, AL
I wish I had my tractor at my house right now. I just couldn't get away to go get it at the camp today. Sure hope a pine tree doesn't fall on it.
troverman
Jun 9, 2015
1,178
264
NH
16 years for me! 2002 L4310 GST with 600 hours or so on it. Just replaced the original battery this late spring. It started fine in the coldest conditions last winter in NH. This tractor was never connected to a tender and sat under a carport-like structure. It would sits for weeks before being used again. When it died, it was from one day to the next. I recall putting about 5 hours on it at wide open throttle mowing. I parked it at the jobsite and shut her down. Next day I arrived to trailer it home, and it wouldn't even turn over. It was very hard to jump start - finally went. Dealer thought it was a record for an original battery.
My 2013 B2920 has 500 hours and is original, and my 2018 MX4800 is of course original but 5 years doesn't impress me at this point!
Dunbar
L2501 LA525 QA PFL2042 Forks RCR1860 FDR1672 BB1560 EA55 WR Grapple FitRite TnT
Aug 2, 2018
217
My experience is that original batteries that come with new vehicles live 50% longer than replacement batteries in the Texas heat. I buy only Glass Matt batteries because I don't like corrosion from lead acid batteries that can climb up into the cables etc. I used to get the Odyssey re-badged as a Sears Die Hard Platinum but the re-badging ended and Odysseys are too expensive otherwise. I get the Auto Zone AGM's and have had great luck so far with the 7.3 powerstorke, Camry and Land Cruiser. I tried to get my tractor without a battery so I could go straight to AGM but they already had the lead acid battery in it. I'll be checking for corrosion and cleaning often.
thirdroc17
185
35
Mine is at 5 years, and try to keep a battery tender on it, succeeding during the winter.
It'll stay in the tractor until it completely fails. I can't afford to replace stuff for the fun of it. When it does fail, that's what jumper cables and battery chargers are for. Though the layout of the BX makes it really difficult to get to the battery posts. Obviously designed by someone who's never had to jump start, or maintain, anything.
stevea
BX2200,FEL, MMM
Jun 20, 2017
Copley
I recently sold a ~17yo BX2200 with it's 2nd battery. The first one was ~11 years old. Wintering in a garage that rarely goes below freezing helps.
Benhameen
2012 Kubota L3800 HST W/FEL and 1963 JD 2010 row crop utility
Jan 27, 2013
713
135
Southern IL.
Just realized my tractor is six years old. Got me thinking about my battery. She is stored in a non heated pole barn and doesn’t get a whole lot of use in the winter.
My motorcycle came with a battery tender and I keep it plugged in when it’s sitting. So I thought it would be a good idea to put one on the Kubota. I didn’t realize some of you have gotten so many years out of your original batteries.
Stopped by the local rural king and bought their brand instead of the battery tender brand. It’s says it’s a battery maintainer and float charger 12 volt.
Specifications:
Input power:120VAC,60HZ, 0.10A
Output:750mA/12vdc
Battery capacity: 5-125Ah
Red light:charging
Green light: maintaining
This stuff is completely foreign to me, so is this the right type of “battery tender” ? Their brand was half price verses the actual battery tender brand. Just curious if I should take it back and get the other one instead or will this one work just as well?
Thanks
