Forks are awesome. Read the manual. For instance mine doesn't want the operator to max engine RPM until 50 hours. If you run all work lights you should be at 2200RPM or greater....little things like that.
Get a daily checklist together that you will actually do. Radiator grill, quick fluid check ( coolant, oil, hydraulic), function check. Consult the manual, then put together a quick list and tape it to the tractor!
If you plan on lifting much, rear ballast is important. Lots of options here. Congrats on the new machine and enjoy. Man I love tractors!
