That's a fact!Yea, but on Criristmas day, 52 is a good day to be outside.
Been a long time. Alas...replaced the oil pump and still no oil pumping. Onto the oil pan...Just about ready to remove front case for oil pump problem. Stay tuned.
Back together with new pump and no oil coming out with filter removed. Onto pan removal Monday.Before you pull the pan, overfill the pan by3 inches. If the suction screeen/tube has fallen off, it should then have oil pressure. Just don't run it long, that much oil will be in the crankshaft rotateing part and produce a lot of spray. Do you have the front back together??
Solvent yes was sucked up. I'm thinking I put in way more than 5 qts as you suggested earlier and didn't realize it till now. Live and learn.Wait a minute. You said you sucked the solvent out of the crankscase thru the hole the filter gets its oil from. If that is the case, the screen and pickup tube is still on. But, I don't see how you were able to do that. The pickup tube goes to the suction side of the oil pump, the pump has to turn to press the oil out of the other side into the filter. You would have to suck the solvent thru the pump and I don't think that is possible.???? If I get time tomorrow, I'll try that on mine and see if I can.
Today is pan removal day.Didn't get time to ck that today. Storm came thru, trees down. May be awhile, but I want to know. I have an L235dt with low pressure at idle that I still haven't figured out. Do you have the front of the eng back on?? Wish I had thought to ask you to look for visible oil galley holes with cup plugs in them . I think I have one blown out.
I don't know the arrangement of the oil pump, but is it turning when the engine turns? Is there a shaft that may have sheared on the oil pump drive?Pan removed. NO sludge build up, NO pickup tube loose. Prior to pan removal a new pump was installed and still NO oil coming to filter or oil sensor. Anyone have any ideas? Time for a hand grenade ? LOL
Mark, new pump installed. Shaft, gear ok.I don't know the arrangement of the oil pump, but is it turning when the engine turns? Is there a shaft that may have sheared on the oil pump drive?
Just a thought.
Mark
Correct. I am really stumped on this one. Guess to the shop it goes.The treaded stem the filter screws onto doesn't lead to the pump and sump. It leads to the main oil gallery! If you force oil in there it will go through the main channel and leak from all the bearings in the engine, eventually finding it's way back to the sump.
How did you replace the oil pump BEFORE you took the pan off?Pan removed. NO sludge build up, NO pickup tube loose. Prior to pan removal a new pump was installed and still NO oil coming to filter or oil sensor. Anyone have any ideas? Time for a hand grenade ? LOL
