How do you deal with snow?
SidecarFlip
Banned
563
I know one thing for certain, we are presently getting freezing rain and I'll be sitting this one out (in the house, off the road, safe and alive).
Maybe go ice skating in the morning. I'm sure the morning commute (which i don't do anymore) will be quite interesting.
Gotta keep those bump shops busy.....:D
Mister
130
Northwest
Used the beast today to clear some heavy and deep snow. MX5800 with chains front and rear, front blade and rear blade turned around backwards and angled is such a great combo on dirt and gravel roads. I have to clear a mile of roads on my property and it makes quick work of it
Sent from my SM-N960U using Tapatalk
bearbait
Dec 9, 2011
4,239
989
New Glasgow Canada
First off nice setup, congrats. Just curious if you've been clearing this road over the years or is this your first season? The reason I ask is it looks like you get a fair bit of snow and as the winter progresses I can't see how you're not going to run out of room to push the snow and how you're going to make it through without having a blower if you don't already have one.
I myself have been clearing a driveway that is 1 mile long ( today looking like it's gonna be one of them) for 7 or 8 years now and yes the last few winters especially the last 1 or 2 I probably would have been alright with your setup however we have had winters that there is no way it could have been done without a blower.
JWool
B2650HSDC FEL & Front Snow Blower, ZT-Z421, GL11000 Generator
Dec 29, 2013
97
17
Northern MI
Snowblower and back blade while in the warm cab of the B2650
Mister
130
Northwest
I assume you're asking me? This is the first season I've had this tractor. Prior to that, we had a guy with nothing more than an F250 and a front snowplow take care of it, and we've had much more snow than you see in these pics. The tractor is a much better set up the way I have it. The front mounted blade on the loaded can lift so high, that I can push tall piles back easily. It is also very heavy and powerful, and can push mind boggling amounts of heavy snow. It's all about having exit push outs, where excess snow is pushed, and then those piles can get higher and higher, and pushed back as need be with the front plow. The rear blade follows along and cleans up, and when I get to an exit push out, I simply raise the rear blade, back over the pile of snow it left, and then push it forward with the front blade. I haven't had to use it yet, but in less than a couple minutes, I can put on my front bucket and actually move piles of snow from one spot to another.
Frostbitten
2019 BX2380
Jul 19, 2012
50
Grand Haven, Mi USA
bx2660 with a bx2750D hydro chute rotation front end blower
Mounted to a bx2751 quick hitch
On the back i have a tarter 5' blade with (2) 41lbs suitcase weights.
I cant think of a better combo that a bx with a front end blower
Its amazing what these little bx tractors can do.
thats how i get rid of the snow
How i deal with snow is usually a nice cold amstel light or a Moscow mule beverage
SidecarFlip
Banned
563
Nice little blade, mine is bigger but so is my tractor and I didn't have any chains on the tires either....
bearbait
Dec 9, 2011
4,239
989
New Glasgow Canada
Thanks for the reply. Yes I was just curious but it seems like you've got a pretty good handle on it. Very nice setup, congrats.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,524
553
We got a little dump again here because it warmed up for a couple days.
I did use the Kubota, but I also took old faithful out for some exercise.
beaterboss
L3901, LA525-FEL, BMLX-3164 3pt Blower, 72" Coteck Sno Pusher, 60" Box Blade
Feb 20, 2017
152
St.Francois,New Brunswick. Canada
Nice setup! Being a snow removal video connoisseur, I prefer longer videos.
Thanks man. Our Internet is frustratingly slow here so we try to keep the vids to a minimum. Thats 34 inches of snow by the way...The 3901 doesnt even slow down at all blowing this stuff. It's like it just plays with it.
Mister
130
Northwest
Nice setup you've got there. What size blade? Might just be the angle those pictures of mine were taken from, but the blade is actually pretty big
dlundblad
G5200, L2501, ZD1211
May 16, 2009
504
IN
Do you ever wish you had the bucket while you have the front blade mounted?
bearbait
Dec 9, 2011
4,239
989
New Glasgow Canada
He can easily change back to the bucket in a matter of minutes. His fel is a quick connect so it's just a matter of lifting 2 levers, dropping the blade, disconnecting the 2 lines going to the blade and putting the bucket back on.
dlundblad
May 16, 2009
504
IN
I meant while he’s using the tractor to plow.
Thanks for the entry level commentary btw. I needed the laugh.
Mister
130
Northwest
So far, no. Since the front blade sits so far out from the front of the tractor, and can raise so high, it's easy to push piles back or even off the side of a hill. The front bucket would only be necessary if I need to take snow from one place and move it a distance away.
By the way, no need to treat that other fellow like that.
