Diesel Additives
armydoc78
34
Jefferson, SC
I add this to every barrel of fuel. Occasionally I’ll add a bottle of Seafoam or Lucas Fuel Treatment to the tank. I do this mostly because of my older JD 3020 and Farmall 806.
bearskinner
Sep 1, 2014
925
241
N. Idaho
Doesn't hurt, and ads Cetain. I usually get Diesel Kleen as it goes on sale a lot at the local tractor parts place.
scattergun
Kubota 2008 B2320, Kubota 2014 RTV 1140
Jul 25, 2017
37
Troy,MI
Are you running the low sulfer fuel or off road. My tractor is a 08 and was thinking about running the off road. I bought a bottle of the lucas anti gel diesel treatment for the winter.
Stmar
B2650HSDC
May 23, 2017
922
45
Buffalo, Wyoming
Temps changed from 80's to 20's in one day, I have about 3/4 tank of fuel with Power Service Gray in it. I was waiting for the winter blend to become available before I refuel. With Gray and 3/4 tank should I be okay as far as condensation is concerned? Tractor is stored inside an unheated barn so it is not out in the weather. Humidity is always very low in this part of the country.
CharlieFoxtrot
B2650
Dec 8, 2016
79
Northeast
For you guys who treat your fuel with Seafoam, do you think it helps prevent gelling? Do you add it to every tank in the winter or just for long periods of non-use?
2,427
Seafoam works by displacing water, that is exactly what an anti-gel will do too.
Add anti-gel all winter long.;):)
countrynerd
BX25D, L3301
Jun 6, 2016
119
thumb, MI, USA
I do the same on both accounts :)
Gundoctor
Kubota M7040 4x4/ BX2230 4x4/ JD MX 8/ Ford 101 Moldboard 3 bottom Plows -
I use a product call "K-100" Diesel. You have many to choose from so look what may be at your dealers. Here in Vermont this keep my fuel from Gel up when -0` plowing snow.
ironbender
B2650; loader/bucket; forks; bush hog; box blade
Sep 2, 2017
34
North of 60*
With the Power Service, the bottle color reminds you which product to use in what season:
WHITE in winter
SILVER in summer
sheepfarmer
Nov 14, 2014
4,447
675
MidMichigan
Any concerns with any additives with a Tier 4 and a DPf tractor?
I think there are quite a few of us using additives, both algae inhibitors and cetane boosters, in tier 4 engines. No problems so far. I had an email conversation with Kubota about them a couple years ago, to see if any were recommended or to be avoided, and bottom line of that conversation was that they didn't. I have the impression that my dpf filter clogs up faster when I put in the anti gel in the fall, and this year trying the type made by Kubota, but I can't separate out the effects of cold weather and the switch to winter diesel.
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
'89 B6200 here - I put Stanadyne, a splash of Seafoam and in the winter Diesel 911. I've never had a fuel problem . . . . (knocks in wood) :D
L35
Jun 13, 2010
472
313
CT
Diesel 911 does not prevent gelling. It only reliquifies waxed fuel.
Butch
Kubota 2410, RC60-24B, FL1000- kubota hydrolic front snow blade- plug aerator
Sep 10, 2009
649
107
Rising Sun, MD
The 2410 started right up this morning.... though it did crank somewhat more slowly. It was a balmy 10 degrees F. Here at the head of the Chesapeake Bay we have the 4 seasons and humidity constantly fluctuating. Between fill ups I notice condensation on the rubber fuel cap seal.
What is the best solution to deal with this in tank moisture?
4,783
Butch - the best thing is to keep your tractor's tank full. There's less room for expansion/contraction to draw moisture into the tank as temperatures change.
