Disappointed
MrC.
Kubota L48, Grasshopper 321D
Jul 26, 2017
Havana, Florida US
Nice work on your rake,
Just a suggestion but you could add may be 4 angle braces from the back of the angle iron to the plate that sandwiches the tines, this would add a lot of strength to the whole rake and help with twisting when side loaded.
Otherwise it looks great.
MrC.
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
MrC.
Always looking for good ideas. Not sure what you mean. From the back of the angle over the top to the iron plate for the tines? Is that correct? Maybe a pic would help if you could. Thanks.
MrC.
Jul 26, 2017
Havana, Florida US
a couple of gussets evenly spaced like this.
You may not need it, try it like you have it, if it flexes to much then add the braces ( they could be solid triangles turned up on the side or just flat plate )
I hope this helps.
MrC.
rkidd
Dec 7, 2015
742
67
Jefferson Ohio
I hope this helps.
MrC.
Ok. I see what you are saying now. Thanks for the pics. I will keep an eye on it and add if needed.
