Fathers day, Mothers day present
pendoreille
B2620, fel, RB1560, Piranha Tooth Bar
Jan 2, 2015
476
Newport, WA
its a lot easier to build it standing on the ground, than lift the whole thing as one piece. It goes quick from there
I will even volunteer my place for a BBQ, meet and greet day. Just manicuring the 1/2 acre yard extension, and I've got more wood than I need for the big outdoor fire pit.[/QUOTE
Yeah, just messing with ya.
What you gonna lift it with? When you do, please post some pictures.
Here are the cans and the process.
captmikem
BX2660 MX 4800 and a bunch of attachments.
Mar 16, 2017
152
22
SW Washington State.
Bearskinner,
Sounds like fun!
do you have any flat grass fields or dirt roads close with no power lines? Someplace I can set my plane down? Need 500 feet but more is always better.
M
bearskinner
Sep 1, 2014
926
241
N. Idaho
Bearskinner,
Sounds like fun!
M
You would need to have a helicopter to land here, this is the only clearing we have in the trees, but the Hayden Airport is only 15 min away
4,105
Airport? We dont need no airport,, tail dragers don't need no stinking airport:D
bearskinner
Sep 1, 2014
926
241
N. Idaho
Well there's a cow pasture down the road, but the critters might not like it! There's a few too many trees to land a plane
2,156
So on the roof construction they jack it up and get it sitting on top of the blocking. Then do they install traditional 2x6(8) support under the trusses just like you would have if the trusses were lifted and placed one at a time?
pendoreille
Jan 2, 2015
476
Newport, WA
The back and center posts are notched. The front truss drops 7 1/2 inches to allow the perlins to cantilever past for overhang. The center post is a 6x8 to allow for the double girder truss. I did not put a 24 inch overhang on rear.
The perlins are 2x8 to get a 60# load. (snow belt).
bearskinner
Sep 1, 2014
926
241
N. Idaho
That's exactally how mine is made, must be standard code for the area. Your gonna love the extra room
2,156
Thank you for the information. Nice way to keep close to the ground for construction. Interesting methods of dealing with holding the trusses up
pendoreille
Jan 2, 2015
476
Newport, WA
In some cases with no overhang they will run the condensation insulation, metal layout and actually screw some of the meal down before jacking.
In conventional framing the more stuff you can get on that wall before standing the better.
pendoreille
Jan 2, 2015
476
Newport, WA
Almost there! a few more sheets of metal, final grading and slab pour on Thursday. Garage door on Monday. The pole builder has a nice eye for detail.
Kubota implements will be out of the weather this winter and still room for 10 cord of fire wood plus another vehicle under cover.
bearskinner
Sep 1, 2014
926
241
N. Idaho
That's nice that they did a clean job on the trim. It does make a big difference when it looks good as well as being a nice build. Your gonna love the extra lean too storage too. You can never have enough storage!
Tooljunkie
May 13, 2014
4,150
Our project is a lift of lumber to strap two 100' long walls on our hayshed. Hoping to get metal up before winter. 4000 square feet to cover, not going to be fun.
bearskinner
Sep 1, 2014
926
241
N. Idaho
So now the concretes curing, and you can walk on it. Have you thought about doing an Epoxy coat on it in a few weeks? It sure makes a nice finish, doesnt stain and repels oil etc. I used the inexpensive stuff from Home Depot, but it's still a great finish for $99.00 for two gallons
pendoreille
Jan 2, 2015
476
Newport, WA
I was actually considering color at the batch plant, they wanted 500 to 700 bucks. I have lived with uncolored in my other shop for 35 years. I can use those bucks for wiring etc. Thanks for the tip on epoxy, will look into that.
bearskinner
Sep 1, 2014
926
241
N. Idaho
It's easy to apply, just roll it on and throw the sprinkles in the air. You won't have to worry about oil or grease spills. I did my lift area 48'x24' with two kits, which is 4gallons. $198.00
When we have the OTT BBQ next month you can check it out.
