I got the reverse gear from Cyprus that Bill told me.
The installation was not bad as long as I could access through the steering gear box hole.
Arrange of forks was not bad as thought. Just position the Hi Lo lever to the middle(neutral) then make all gears are free to turn(no engagement ) then put the reverse gear fork first and 2 other forks. At that moment ignore the pto fork.
Once put the forks on the reverse gear and two other gear then lift the cover from left side only about 1/2" then place the pto forks( the pto forks are most shortlist that is reason it was easy to put gear forks first)
After two top covers were on the positioned then installed the steering gear box and shift installed fuel shutoff valve, replace fuel filter( looks like it never been replaced) flushed engine oil couple time(engine oil looks like never been replaced too)
all works has done about 3 1/2 hours and the tractor runs very well.
Next challenge is the 3 point hitch. The previous owner made basic hitch which is no safety chain and no leveling between the left and right arms.
I already modified to put the safety chain and connection and will install the heavy duty bolt between the right sidebar. If it doesn't works. Will buy used one from local guy who has many used Kubota parts.
Will update.
Thank you for helping me specially Bill and wolfman.
Will update.
