What did you do to your Implement today
billrigsby
Mar 17, 2015
1,050
247
Florissant CO USA 8213'
www.facebook.com
fatjay
Kubota B8200, B7200, ZD21
Nov 12, 2016
355
235
Eastern PA, USA
That looks great! How much sanding do you do before you paint? I have a few things I need to repaint, I was just going to hit it with the pressure washer to get the paint flakes off, but thought it might not be bad to sand some areas as well.
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Did a lot of wire wheeling where there was bad rust , then just a light sanding over some of the original paint and a quick solvent cleanup before painting.
Bill Rigsby
Florissant CO
1972(?) KUBOTA L-1500-DT
Great Bend M10 48" Front End Loader
Bush Hog 48 (SQ48R-3) "Squealer Mower"
Atlas 48" Landscape Box
48" Harrow Rake
Rhino 60" Rear Blade
4 Seasons haul-all Dump Trailer
Draw Bar with 2" Ball
28" Fork Lift Forks
Sent from my Samsung Galaxy S7 using Tapatalk
7,621
You guys do nice work!
Bill, after all the clean up, painting and decals you neglected polishing your hitch pins on you rear blade.:D:D
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Yesterday I started on the A-Frame fabrication for the PHD
Had this laying around (or is it lying around) in the scrap pile
Cut down some 1/4" angle iron for the bracket
Drilled a couple of 3/4" holes and tack welded together
Tack welded it to the A-Frame metal and test-fit it
Welded it all up
Now I just need to determine the proper length to get the maximum travel,
cut and weld some brackets to the bottom and add a pair of Cat-1 hitch pins.
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Today it is just too dang cold to do any shop work,
even with the heater running ! (I did try) :mad:
I must have too big of a shop OR too small of a heater,
leaning toward needing a new heater :eek:
So it was all about re-creating the warning decals for my Post Hole Digger.
Leinbach went under a couple of years ago so to the computer I went. :D
and now that is above negative temperatures, time to get plowing
IN A HEATED JEEP :D
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Finished up the A-Frame tonight, happy with the up-down travel.
Welded a couple of tabs to accept the new 3-point pins
did a test run,
I ended up with 19.5" of clearance in the full up position, can get more with the four additional holes available on the boom ;)
and goes all the way to the ground and then some in the full down position ;)
I am wondering if it is proper to have the 3-point pins on the outside and tighten up against the lynch pins, Pulling the A-Frame outwards
(would make for an easier installation)
or should I have the pins on the inside? :confused:
Next is paint and decals, weather permitting ! :D
bucktail
Jun 13, 2016
1,297
220
MN
You must have an impressive scrap pile.
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Well I have been known to stop on a dime when I see a chunk of metal on the side of the road LOL
AKA junk collector.
I've been told my garage looks like a hardware store but when you live a half hour from the hardware store you need to be well stocked.
Bill Rigsby
Florissant CO
48" Harrow Rake
Leinbach L7200 Post Hole Auger (9")
28" Fork Lift Forks
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
That exposed PTO shaft has me nervous. Otherwise looks great.
Yes tis the life of a grey market tractor , I may make a cover for it. I do have all the covers for the auger end of the drive shaft however.
I never understood the theory that grey markets do not have PTO shaft covers there's one listed in my parts manual finding it might be another story though , just another fab job probably.
But, thank you for your positive comments.
Bill Rigsby
Florissant CO
48" Harrow Rake
28" Fork Lift Forks
billrigsby
Mar 17, 2015
1,050
247
www.facebook.com
Well if Winter would ever get here maybe I could rest a bit. :rolleyes:
Today I got all the auger parts painted,
first I removed all the warning decals...
then a quick pass with the wire wheel...
and a coat of primer and Orange and Red paint...
then everything in the greenhouse to dry...
(May not be snowing much, but it still gets cold :p)
Now time to order the new decals :D
Picked up new Stainless Steel hardware today.
7,621
I was wondering how paint dried in that weather!
Need more to do? I can send a plow, pulverizer, disc, couple of 5' brush mowers, tiller, trailer or two..... sub-soiler, bale spike......
You seem to enjoy detail work!! Looks good. Takes a lot of patience.
