New 2 me L2850 with engine knock.
11,110
One small hic-up that I just found, it does not have the fuel pump hole in the side of the block, and you will be removing the fuel pump that is on there now, you could go through the trouble to drill and tap the holes in the block for the lift pump, but you would be much better off just putting a low flow low pressure electric pump on it to make it work, and it would probably work better than the old pump anyways. ;)
Wild and Free
B2150 HSD w/Case L340 fel 68" quicktach bkt, 60" jinma snowblower, box scraper
Oct 25, 2012
390
North Dakota
Looks to be a different style fuel pump plus I need to mount the hydraulic pump off the back side where the primer pump is on the pic of the v2203.
I read a thread on here where a guy posted a question about a difference with this as well on the same retrofit as we are discussing but nobody responded to him, I have tried to send him a couple messages to see how he resolved it with no response either.
11,110
Yes the pump that is mounted on the back of the Injection pump is an active pump, use to pull fuel up from the bottom tank on a reefer unit.
I'll post a bigger close up picture of it tomorrow for you to see. ;)
Wild and Free
Oct 25, 2012
390
North Dakota
Thanks will be nice to know all of what I would need to change before pulling the trigger, I am lucky in the fuel dept. as the fuel tank is higher than the engine on this tractor as it sits right in front of the steering wheel.
11,110
One thing I thought of is the pilot bearing, pull your clutch and give me pics and dimensions of what is there.
I will get dimensions of my V2203 Newer crank, and if cviola2005 has a older V2203DI hanging around maybe he can get some measurements too.
Here is what the side of the block looks like around the injection pump.
Wild and Free
Oct 25, 2012
390
North Dakota
This weekend I will get to that, working night shift this week so mornings are short for getting anything like this done.
How is the primer pump assembly attached to the back or side of the injection pump housing? this is what I can't seem to see good enough in all V2203 pics so far.
Just looking if my hydraulic pump will bolt up to the rear of the IP hassle free and like another post a guy had here he ran into an issue with it in this post.
http://www.orangetractortalks.com/forums/showthread.php?p=129365#post129365
11,110
I'm not sure what his issue was, as they both take the same splined cam shaft end????
Maybe he didn't notice that there is a blank sleeve/cover over the splined shaft to hold the back bearing in place when they don't use the pump gear, like in the second photo???
Also note that even though they don't use the fuel pump cam on most V2203's it's still on the camshaft (it's the ring/skinny lobe between the 3rd and 4th cam lobes)
V2203 Camshaft
V1702 / V1902 Fuel Camshaft / with blank cover / sleeve over cam splines.
Wild and Free
Oct 25, 2012
390
North Dakota
OK guys dimension comparison time. Got the clutch and flywheel and rear housing off the 1702.
Bell housing is 100 mm thick
clutch assembly protrudes 70mm past rear face of flywheel housing measuring the furthest point which was the clutch finger castings of the pressure plate assembly.
distance from outer edge of flywheel where the pressure plate bolts to it to the rear face of the bell housing is 35mm there is about a 2mm step out where the clutch plate rides so if measuring from clutch face it would be 33mm
distance from rear face of crank shaft to rear face of bell housing is 72mm but take into account the crankshaft is broke and it looked to be about 2 mm out looking at the rear main seal so it may be closer to 74mm but just a guess
flywheel total thickness is 47mm
Gotta say everything looks like new yet clutch disc lining and splines in the hubs and on the trans and pto shafts as well, release bearing looks and feels great and pilot bearing looks and feels great but will get replaced with replacement engine.
11,110
The back of the crank off of the block will be exactly the same, and the dia of the crank and bolts will be the same, as it was for me.
What I need to know is the OD and depth of the pilot bearing to make sure it will fit for you. ;)
Wild and Free
Oct 25, 2012
390
North Dakota
More info for ya.
Crank shaft diameter is 80mm
Pilot bearing thickness is 10mm and depth of hole approx. 15mm without having popped bearing out.
pilot bearing OD 30mm
Pilot bearing ID 14.9mm
Shaft OD where it sits inside pilot bearing 14.8mm
11,110
Just measured it and yes the V2203 is the same size. :D
Wild and Free
Oct 25, 2012
390
North Dakota
Just to be sure, the oil pan and flywheel hsg from my 1702 are a direct bolt on to the 2203 then? Also what about the flywheel, would mine be a direct swap?
If so then I will go ahead and order up a used engine next week.:D
11,110
Yes everything I have measured says that it will work perfectly! ;)
Wild and Free
Oct 25, 2012
390
North Dakota
Well got the ball rolling on a used engine. Waiting on final invoice with shipping costs, may be a week or so before seeing the engine.
From visiting with guys from 3 different companies selling these used V2203 engines as well as cviola2005 here all of them seem to come out of reefer units so they shouldn't have seen any "abuse" so to speak.
I am going to start a new thread and document the process the best I can for doing the V2203 retrofit into the L2850 tractor once the engine shows up.
Wild and Free
Oct 25, 2012
390
North Dakota
Just a tid bit of info, i have been looking for a tractor that runs the V2203DI in as close to the same size and vintage as my L2850 that was built from 1985-1990 and the only one I came up with is the L4350 built from 1991-1995 which runs the V2203DI and is rated at 47.5 hp. Hope this helps some as well going forward.
Still waiting for an engine to ship.
