Wild and Free
B2150 HSD w/Case L340 fel 68" quicktach bkt, 60" jinma snowblower, box scraper
Just acquired a deal too good to pass up. Got an L2850 4x4 shuttle shift 1700 hours with Kubota loader and fairly new tires that is in overall excellent shape except the engine has a bad knock and the front crank seal leaks like a sieve.
What put the deal over the top was it came with a John Deere 272 finish mower that was recently gone through new blades tires and is in about new condition overall as well, also a 5' TSC box blade well used, a 3pt cultivator and a very good condition 6' Tarter rotary brush mower all for $4500.
I plan on fixing the engine and using the tractor for a bit to see if I want to hang onto it or sell it but will be opening up the engine to see what let loose in it. I bought it as is did not try to start it so as to not cause anymore damage but did turn it over just enough to confirm is has a knock.
My question is where is the best spot to buy either engine parts or if it is bad enough a reasonably priced used or reman engine?
Have not been on here for quite a long time, my B2150 just purrs away issue free. Just hope it doesn't get jealous having a new big brother around.
