Put on bell housing, next: put block onto tractor
Tightened all bolts, almost forgot to hammer in the keepers on inside bolts
Took about 30 minutes to figure out how to line these bolts for flywheel
Hit them hard with impact gun once I get electricity (waiting on the sun)
Hammer in those keepers, put on clutch assembly, put entire block onto tractor
Hit the flywheel bolts with air powered impact, hammered in the keepers
Clutch plate sitting on clutch but won't be flush with flywheel
I remember it being flush
Up close, you can see clutch plate hitting clutch, not allowing plate to be flush with flywheel
Now: go look at diagrams and see if you forgot something, let me know what I did wrong
ok I think it is solved
There was 2 size bolts, some shorter some taller, once I got them in, it pushed the plate inward and now it sit flush, some bolts did not go down the whole way, switched them out with short ones until all 6 bolts sit flat
Now: Tighten those bolts by hand, flip block upright, lift block and somehow get it back onto tractor
Built a pad near tractor, tried to lift it onto pad, cant, forgot how heavy it is
Now: Put straps on it lift it with bx1500
Moving block using loader on small tractor
Finangling block into position, tight space
Got block close to tractor
Dropped block close to position, built it up using lumber
Now: brainstorm how to push it into tractor
