Back on the hinge while waiting for parts
Mixed acetone with trans fluid, apply with brush, hit hinge with torch
If chinese gaskets make it: make progress on engine
Still don't know why both starters are doing the same manner like the video posted earlier
"Braided wire going to it" is ground, correct?
In my head, this is connecting positive and negative and causing a short
Or am I incorrect?
Summary: work on hinge, figure out why both starters won't spin, and get gaskets to continue reassembly of block
Woah look at this: chinese gasket kit for $100, ordered on Monday from China, got here today (Thursday)
Now: forgot about the hinge, get back to engine assembly
Installed oil pump: put gasket on, got it into proper place, put in long bolts,then short bolts, then looked at diagram, put in the small key, then placed gear with protruding end facing front of tractor
Put gears and their hardware on not too tight in case I make mistake
Starter problem solved by @kutobaguy007, ground wire on engine block not on starter
Video: engine spin fine, that gives go ahead to keep rebuilding...
This statement could be on to somethingIf everything is lubed, try this. Connect the (-) cable to the block or starter mounting bolt, then touch the (+) to the stud on top with the braided wire going to it, that should bump your starter. Forget about the signal wire for this test.
Or am I incorrect?
September 12, 2024
youtube.com
