I think I'd like to see a straight edge posed in various locations across the deck.
That block had such little wear, i cant find anywhere on it to clean.
It only had 600 hours, thats only 6 oil changes
The reason why it popped a hole in the block: it must've sat for a decade or 2 without starting once
Then once it was started again, parts were seized and damage occurred
Shouldn't deck be square and plumb since he "Plained all flat surfaces with 80 grit flap then 2800 rpm wire wheel"?
Not only are you seeing the pictures, but you are reading my narration, I am honored
problem is finding a machine shop that CAN do it right.
There are very capable machine shops that can mill the liners, its just that I am a nobody and cannot get their attention
Now, economy slowing down, people are more available, I can see it working out where:
If I offer the extra $150 tip, some guy might stay late and mill the liners faster
Also, that last machine shop had a hundred engine blocks all over the ground, and one guy working 15 hours a week trying to keep up, zero chance he was going to get to it
I will only leave the block there if I see evidence of motion and more people working
Soon: I load block that needs milling, I go show up in person, there are 3 machine shops I will give a try
That extra cash tip is the answer
My offer: pay the shop rate, and offer the cash tip to the exact person that does it
Also I notice with these kinds of places, you can't really call them, it's better just to show up in person
I keep having to find this, give this to machinist when giving block
3 things to give machinist: block, piston, and that sheet
Dirty block been sitting out getting wet
Washed block with free rain water
Now: go to machine shop and stick to narrated plan
Yes I wait now for library to open, print out 10 of those sheets
That way, I hand the machinist everything in one shot, no need for him to look up specs, he'll have: clean block, spec sheet, and a broken piston as reference AND the $150 cash tip if completed within a month
Showing you up close the milling required on two cylinders
