Zerks
PorkBolt
B2601, 60" MMM, SSQA FEL, Kubota Ballast Box
Sep 22, 2015
38
Elburn, Illinois
B2601 and loving it; went to service the grease points on the anti-scalp rollers. Hooked in, greased them, and when removing gun pulled out the zerks. Anyone else have this issue? Solutions are also solicited....
dfh1977
198
east ky
I would guess check to see if the zerks are tight in place and tighten up if needed. Check the one that came out if they were just loose
whitetiger
Nov 20, 2011
2,679
1,180
Kansas City, KS
Yea, that happens when you screw a zerk into a plastic wheel. You probably need to unscrew the end of your grease tip a bit so it releases easier.
kckndrgn
BX2370 w/ 60" MMM and FEL, Box Blade, Bush Hog, Carry All & Tiller
Mar 17, 2016
150
Somerville, TN
Yeah, my dealer advised that if the grease gun has difficulty releasing from a zerk to loosen up the gun tip.
2,280
Diydave
L2202 tractor, L185f tractor
Oct 31, 2013
1,635
Gambrills, MD USA
If its in plastic, drill the hole out, a little bigger, and tap it to the next size fitting up. You don't have to use the drill the tap recommends, plastic is easy to thread. Oh, and try the lock-n-lube, when you hit the release lever with your finger, it releases easily...:D:D
4,276
Until you get a Lock-n-lube
What Hokie said....haven't pulled one of those scalp wheel zerks out after getting it...
Didn't like spending $30 for it either, but the gun with it on is the only gun I use anymore...
chieffan
B7100HST w/RC60-71B Deck
Jan 12, 2016
89
SW Iowa Adams county
A lot of grease zerks are drive in. Saves time in building and the customer has to fix the problem the mfg. creates. The ones in iron are an easy fix. Weld a 1/4" nut over the hole and thread in a new zerk. Problem over with.
