So, the short version is my ZD326s is giving me trouble starting, I can start it by jumping from the positive lug on the start to the solenoid. I was mowing, parked it, came back 5 minutes later and it wouldn't start.
Symptoms
- Flickering or non-illuminated lights on the Easy Checker with key in 'On' position
- Sometimes the first 2 lights light in the on position and the steady 'clicking' from under the hood, but then when trying to start there is a 'click' under the hood and all lights go out.
- Frequently the key will not stop the engine when switched to the off position.
Things I've done
- New Ignition switch
- New safety switches all around
- Tested all fuses in the fuse box under the seat, and the large red one near the starter
- Checked the voltage on the battery with my multimeter, getting 12.96v
- Replaced Starter
- cleaned / reseated the 2 connectors from the console.
- Checked the ground strap near the starter.
I can start it using the solenoid and kill it using the kill under the hood, but obviously I want to get this fixed. Seems like a electrical issue back to the console but I'm not sure where to go from here.. I guess I should check continuity between the connector on the rear of the the key switch and it's connector under the seat, but beyond that.. I'm looking for ideas
Thanks for any advice any has!
Symptoms
Things I've done
- Replaced Starter
