ZD 21 deck hydraulic cylinder
RHR
MX-5200 KX-71-3 ZD21F-60 Cat D5K2 Cat 324E L
Dec 14, 2021
55
TEXAS
Can the cylinder be repaired? It is leaking around the rod.
Workerbee
Zd21
Mar 1, 2020
387
271
MN
Most likely its the seal. Your first step is to remove the cylinder, then take the end cap off and get the seal for it. Or take tge cylinder in to a hydraulic repair shop.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,959
2,459
WestTn/NoMs
Your cylinder is single-acting, similar to the one on a GR2100. You don't actually remove the gland. There's no separate piston; the rod acts as a plunger. There's a clip to remove through the hose port; then the rod can be pulled out to replace the seal and wioer.
Here's a link
RHR
Dec 14, 2021
55
TEXAS
Here's a link
Thanks
