Wire with connector coming out of the front?
sowhatofit
Elmira, Mi
So I've got this wire/connector that was sticking out the front of the grill in this L3430 I bought a couple years ago. Finally got around to try and figure out what it does. It's connected to this toggle switch, which snaps back to center when switched up or down. Continuity test shows power in the run position only when the switch is flipped up or down and ignition is in the run position. Any thoughts?
GrizBota
Apr 26, 2023
1,147
732
Oregon
Looks like about a 15 amp switch and similar capacity wire. Maybe to run the relay for an electric winch or other accessory that was on the FEL when the bucket wasn’t. Maybe a home brew grapple with an electric over hydraulic cylinder. Had one on an old Scout to lift the plow. See any aftermarket lugs on the battery?
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,327
1,939
WestTn/NoMs
BIL has a similar deal on his Ford 1520. He has/had a seeder, I think.
Edit, I did a less elegant install to power my 25 gal sprayer.
sowhatofit
Elmira, Mi
Didn't think of that. Doesn't appear to be My after market lugs on the battery.
Donystoy
Dec 10, 2013
671
305
Binbrook, Ontario
This is exactly what I installed on my tractor to operate the linear motor that I installed on the snowblower chute deflector.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,693
2,011
Near Lancaster, PA, USA
My linear actuator for the QA is two-wire. A DPDT spring loaded center off switch on the dash reverses the polarity so the actuator can move both ways. I used two inside wires on a female 4-wire plug on the tractor side so there's never an exposed 12V+ terminal.
