On this deck the gear box is in the middle facing forward, I think mine needs to be offset to the right facing forward? I will attach a few pictures later. I wish I could make this deck work as it is for sale somewhat close to me. I have a 2WD manual shift B6200 with no mid PTO whatever that is?I think you might be mixing things up....
Which model tractor do you have?
A D or an HST
The 6200D called for a RC60-72
Where the 6200HST called for a RC60-72H
If you have a RCB60-1 deck for the B8200D, the driveshaft should already face the front of the tractor for a crank driven PTO, so no directional swapping is needed, where if your trying to use it on a mid PTO driven HST model that deck will not work.
No, it's a completely different design and will be complete different mounts.sorry hoping some one can help I have a B7100 with a mid mount PTO, but purchased a deck with front mount crank shaft PTO ( from a b6200) . can i just turn the gearbox around 180 deg and adjust pto shaft?
