Will a RCB60-I deck fit a B6200 with a front PTO?
5,923
Jay, I am pretty sure that is the correct deck. I had a B8200 and have a deck for one. It's an RC60-71B (I'm pretty sure). It's low hours of usage, just been sitting since about 1985! If you need a deck or parts let me know. I have no use for it.
Lineman
Harwood, Md.
Thanks, that would be great!! and even better if you were not so far away from me. Mine has drive from the front set up so I think it called for a different deck and not sure if you can just turn the gear box around?
Thanks again Jay
7,240
I think you might be mixing things up....
You have a B6200E which called for a RC48-62F or RC60-72
The 8200D called for a RCB60-1
If you have a RCB60-1 deck for the B8200D, the driveshaft should already face the front of the tractor for a crank driven PTO, so no directional swapping is needed.
But the RCB60-1 takes a different set of mounting arms, made specifically for the B8200D, they are not the same for the B6200E.
B6200E deck RC60-72
B8200D Deck RCB60-1
Lineman
Harwood, Md.
Which model tractor do you have?
A D or an HST
The 6200D called for a RC60-72
Where the 6200HST called for a RC60-72H
If you have a RCB60-1 deck for the B8200D, the driveshaft should already face the front of the tractor for a crank driven PTO, so no directional swapping is needed, where if your trying to use it on a mid PTO driven HST model that deck will not work.
On this deck the gear box is in the middle facing forward, I think mine needs to be offset to the right facing forward? I will attach a few pictures later. I wish I could make this deck work as it is for sale somewhat close to me. I have a 2WD manual shift B6200 with no mid PTO whatever that is?
Jack
B8200 BF300 FEL, 4530 Backhoe, Kubota B7100 HST, Kubota G5200, Kubota B9200TLB
Dec 20, 2010
29
Aurora, Ontario
sorry hoping some one can help I have a B7100 with a mid mount PTO, but purchased a deck with front mount crank shaft PTO ( from a b6200) . can i just turn the gearbox around 180 deg and adjust pto shaft?
7,240
No, it's a completely different design and will be complete different mounts.
Jack
Dec 20, 2010
29
Aurora, Ontario
wolfman thank you, i am quite handy, cut weld and can be creative, can you possibly give some insight as to major issue will be.
For mounting all brackets bolt to the tractor have not put deck on to see if centers of brackets are correct.
I am more worried about gearbox and rotation?
