What do the little numbers mean in the wiring schematic?
dgarvin57
2008 B2920HST, LA403 Loader, BH65 Backhoe, RCK54-29B Deck
Sep 22, 2016
Athens, TX
I am looking at the wiring schematic for a B2920 and I see little numbers ranging from 0.85 to 0.5 to 2.0, etc. They appear right next to the wire color. What does these numbers mean? Thanks.
2,551
Is it DIAMETER of wire in MM or Sq MIl's?
I think it is diameter - might be wrong - but as you can see - big difference between
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,235
1,018
Williamstown Ontario Canada
I am with Jim L.
The number is the cross sectional area of the wire measured in square millimeters.
Fusible link wire markings make this fact clear.
Dave
dgarvin57
Sep 22, 2016
Athens, TX
That makes sense. The larger the number, the thicker the wire. Thanks.
2,551
That is true in metric ..... were as SAE - it is a$$ backwards ..... like shotguns.... smaller GAUGE means bigger
1,415
If you think of “gauge” as “how many times did it get rolled thinner” it makes good sense. So 2 gauge (twice through rollers) is thicker than 10 gauge (10 times through rollers).
4,908
If you want real bass-ackwards the Metric 'equal' to MPG is L/100Km !!! But it's not, it's TOTALLY different...
