ACDII
Oct 21, 2021
681
424
Illinois
Was considering taking advantage of the 50* temp today and finish splitting and stacking, but right now it is 37* with a 24 MPH wind. That is not 24 MPH gusts, that is 24 MPH wind, gusts are up to 45 MPH. Needless to say when it is that windy, 50* does not feel that warm.
Oh I wish I had my new tractor now, at least with the cab I can climb in and warm up every few minutes.
foobert
BX2380
Mar 25, 2021
110
105
Washington
I had no idea you could use one of these spreaders for ag lime. Everyone here says you cant because ag lime will clump up in that type spreader. Whats the secret?
I’d read similar statements and knowing what commercial lime spreaders look like, I also had some initial doubts. The biggest issue I’ve encountered is that the throw distance is rather short; I get about 5-10 ft spread on left side and the nothing past the right wheel track. That’s fairly pathetic compared to prilled/pelletized material, but, for my few acres, it’s no big deal at all to adjust the driving pattern to accommodate.
The spreader has an excellent agitator and I’ve had zero issues with it feeding. The standard speed-n-feed calibration is useless. I’m running the feed gate about 80% open and now have a rough feel for right speed for 2 passes to hit my application rate.
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
249
444
Moseley, VA
Finally got the chance to get some of the firewood up that I had dropped and split a few weeks ago. Eight loads, plenty of firewood for next year or the year after as I have another two cords in the barn that I cut last year. Finished the day off putting the box blade on and doing a little grading for a family member.
nbryan
Jan 3, 2019
1,304
826
Hadashville, Manitoba, Canada
Three hours of driveway clearing today. A rescue the neighbor job - notice the tractor-shaped object just to left of drive ahead. He's got a rear blower but is stuck real good.
Nasty little blizzard the last few days here in SE corner of Manitoba, probably 30+ cm over a few days, and now the WIND from the north. Maybe made a high of -20C today. Windchill? Nasty.
S-G-R
Grand L5460
Jun 17, 2020
1,357
3,153
PEI Canada
Slime!
It's ugly/messy stuff, but it works!
Agree 100%. My front R3's have a lot of plugs. I had both front tires done with slime three months ago and they are still holding the exact amount of air. I hope the upcoming R14's are tougher.
lynnmor
B2601-1
May 3, 2021
1,570
1,329
Red Lion
The R14 appear to be rather flimsy compared to anything other than a turf. I think that the jury is still out for long term performance. And good luck finding Kubota's recommended inflation pressures, unless they finally put them in the owners manual.
ACDII
Oct 21, 2021
681
424
Illinois
Slime!
Same here, all 4 tires have it in them as all 4 tires had a puncture at some point. I think I add air once every other year.
S-G-R
Grand L5460
Jun 17, 2020
1,357
3,153
PEI Canada
I'll find out how good they are this summer although from what I saw on the lot they appear to be thicker over the R3's.
S-G-R
Grand L5460
Jun 17, 2020
1,357
3,153
PEI Canada
Fixed my two leaking hydraulic fittings on my snow blowers chute deflector.
RalphVa
738
321
Charlottesville
Used the old ()2015) Frontier green bush hog on my orange machine today for the first time. Lost my cat 1/cat 2 and cat 2/cat 3 bushings off the left side. Somehow the pin got knocked out. Ordered new bushings and different kind of pin from TSC. Still lots cheaper than those $38 ones you have to put on each implement. (Needed for the WH QH lift arm locations to keep pins from shifting.)
GrumpyFarmer
3,999
Leveled a base with the little monster for the greenhouse build, then drank some sap…not quite enough to boil, but more than enough for a refreshing drink in the woods…we are very close to the season though. After that I thought I should come inside and cleanse my pallet with some water that flowed over limestone from Knob Creek area and aged in a charred oak barrel. 🥃
foobert
BX2380
Mar 25, 2021
110
105
Washington
Today is a Good Day — my daughter’s rabbits are officially out of the house and that festering parenting fail can start to be forgotten. ‘Nuf said about that, onto the tractoring…
The new neighbors on the property adjacent to us remarked they couldn’t give away the aviary that the prior owners left, and my wife piped right up that it’d be a perfect structure to house the rabbits, and wouldn’t it be so easy now to just pop it over to our place and solve everyone’s problems? Hah! Two full weekends worth of work, I’m happy to report that it actually is quite a nice enclosure.
It’s about a 10.5’ diameter heptagon (7-sided) structure made from extruded aluminum framing that has 100’s of bolts & self tapping screws holding it together. It probably weighs no more than 125#. It took hours to remove all the intertwined vegetation and free it from the timber foundation it was on. The last thing I wanted was to then disassemble it for moving.
So, I made 11’ fork extensions by C-clamping a pair of rough-cut (full dimension) 2x4’s to the forks, and then screwing some cross-beams to that to support the structure from 8 points. Interestingly enough, my 160# hanging out at the very end of the 11’ extension is enough moment to just lighten the rear axle of the BX w/ rear-blade as counter weight (but no operator) such that one rear wheel lifts slightly. No problem: 1) the moment arm of the structure is centered at half the fork length, 2) it weighs less, 3) my operator mass will help counter. But, it was a fun test.
5 of us lifted it onto the forks and screwed the base down to absorb some of the wobbles and carefully drove several hundred yards of driveways and public road to get it moved. The lil' BX didn’t hardly even shrug at the job.
Hand dug 16” depth of anti-dig wire and built a cinder block foundation and set it into place. The kiddo helped out with the entire process and I couldn’t be more proud of her efforts — she’s really happy with the result she helped create.
Reactions: 10 users
3,093
Isn't it always amazing how many different tasks these tractors help out with? :)
Chanceywd
Mar 26, 2021
690
612
central ny
Actually My 8N has been there making life easier for me for 25 years. The L2501 retirement tractor is with the FEL and Bh77 is 10x 8N amazing. But I kept the 8N and it is till my snow plowing and other uses so it didn't get replaced. Like me it is getting help from the kubota!
Bill
In Utopia
L175 FEL
Apr 21, 2013
639
154
Utopia,Tx/Pasadena,TX
I used to use Slime, until I found this stuff.
First used it on a neighbor's skid steer tires. His rims were in bad shape. Used this stuff, never lost a pound of air. I used it as a test on a utility trailer that had leaks from dry rot. Trailer is only used on my property not on the road.........no more leaks. Got it in all my tires including my golf cart tires.
ACDII
Oct 21, 2021
681
424
Illinois
Just don't put it in car or truck tires. It causes balance issues, and if you do need a repair, most tire places now hit you with a cleaning and environmental fee. It's nasty stuff to clean up.
Shekkie
LX2610, Virnig 60" Grapple, WoodMaxx TM-86H, Woods 60" BB/72”RB
Feb 12, 2022
183
306
Grafton, Ohio
Ordered a Virnig V30 60” grapple for my LX2610 today. Just gotta decide on which 3rd function kit now.
Ikc1990
Kubota m125x, m9000, b2710, and other equiptment
Dec 2, 2020
292
130
Vermont
Also ruins the tire pressure sensors if you have them
