ken erickson
Nov 21, 2010
1,147
1,856
Waupaca Wisconsin
I finally made a decision on a size & ordered (2) new 29-12.5-15 rear turf tires for my B6200. I'll measure the inflated circumference before deciding on new front tires. The cheap Carlisle 21-7-10 front tires I already purchased have a smaller inflated circumference than my original Bridgestone 20.5-8-10 front tire, so they aren't technically true to size, & they are only 2 ply instead of the 4 ply I ordered. Not yet sure if I'll replace the incorrect front tires with 20-8-10 turf tires or find trailer tires with the correct circumference.
Kenda Tire does offer a 4 ply in your original Bridgestone’s tire size if interested.
20.5-8-10.
ctfjr
L3800HST
Dec 7, 2009
1,879
2,293
central ct
I finished cutting up that massive tree branch that I pulled down. I don't burn firewood so I just put whatever I cut on the curb. It usually gets taken in a day or two. No point letting it rot in the woods.
Then I spent a few minutes determining why one of my led replacement bulbs in the rear fender light was really dim. Bad ground. Kubota uses the fender as the ground leg. The light socket on the other end is a hollow threaded tube. The single wire goes through the tube to the center connection and the threaded tube is supposed to make the connection to the fender. It was pretty corroded and nasty looking.
When I tried loosening the 17mm nut the whole light was turning. I put mouse milk on it and will let it sit until tomorrow but just working it back n forth caused it to make a better connection.
It was barely glowing before. Worst case, I'll clean the threaded portion, put another nut on over an electrical eyelet connector and run it over to a better ground.
Newaterman
LX2610 HSDC, Z422-54KW
Feb 14, 2021
99
274
53
Vermont
50 hour service today….at 52 hours 🤷🏼‍♂️. Then I grabbed some rocks that had been dug out some weeks back. Cleaned up a couple more trees yesterday that I had felled for esthetic purposes.
Reactions: 9 users
RichardAaronlx2610
Aug 3, 2021
441
490
New Jersey
bird dogger
Vendor Member
Feb 24, 2019
1,601
1,457
North Dakota
View attachment 67657 View attachment 67658 View attachment 67659 View attachment 67660 View attachment 67661 View attachment 67662
You have a beautiful spot, Newwaterman!! With all your trees and woods, a pto powered leaf blower behind your LX2610 would make your fall leaf cleanup a breeze. A few of us here have them. Been using mine for the last week. the leaves just get blown right back into the woods.
B737
LX3310
Jun 9, 2019
2,024
2,200
someone get @Newaterman a PTO leaf blower asap! :ROFLMAO:
Newaterman
Feb 14, 2021
99
274
53
Vermont
If you don’t mind me asking, how much did it cost you to do the entire service? And what did you do?
$87 I believe, engine oil change, and both hydraulic filters. Dropped enough hydro doing the suction filter that I more or less changed half of that 😂
Newaterman
Feb 14, 2021
99
274
53
Vermont
thank you, and I’m sure the mrs would love to see another pallet arrive from the dealership!
pokey1416
Jun 24, 2020
556
825
SW Michigan
Great afternoon using the chain harrow. Worked the thousand yards of wood chips in the park and then hit the parking lot. These days away from the desk and office are heaven!
Reactions: 7 users
michigander
547
234
Northern Michigan
Found out from my wife tonight after last mowing of the season she is expecting me to give her tractor yearly bath before parking in the garage for winter.
Magicman
Oct 8, 2019
5,513
7,576
Brookhaven, MS
knotholesawmill.com
This was waiting for me at the entrance to my property this morning.
So I had to gitty-up-go and git er done,
All done and here I am parked under my entrance; The Davis Vineyard, LP, but no grapes have been grown here since the mid 1800's which was before my G Granddad bought it in 1899 & 1904. I bought it in 2004, which was exactly 100 years after he bought it.
Reactions: 7 users
RichardAaronlx2610
Aug 3, 2021
441
490
New Jersey
Not sure if anyone else had this problem or not, but my hoe levers on my bh77 backhoe would hit when pushing them towards the outside of the machine. So I cut them and centered them in the hole and re welded them. Now it swings perfectly and the bucket opens properly. Nothing like cutting apart a brand new machine lol
bird dogger
Vendor Member
Feb 24, 2019
1,601
1,457
North Dakota
Not sure if anyone else had this problem or not, but my hoe levers on my bh77 backhoe would hit when pushing them towards the outside of the machine. So I cut them and centered them in the hole and re welded them. Now it swings perfectly and the bucket opens properly. Nothing like cutting apart a brand new machine lol View attachment 67895 View attachment 67896 View attachment 67897 View attachment 67898 View attachment 67899 View attachment 67900 View attachment 67901 View attachment 67902 View attachment 67903
When my BH77 arrived in 2019 I was putting it through its checkout ride in an open area. All of a sudden, an outrigger would retract and I thought I had broken something. Nope. A little while later....same thing. Now paying attention, I found a combined motion of swinging the boom to the right and up would cause the rubber boot to activate the stabilizer lever and the tractor would drop on that side. Same combination on the dipper stick would do the same on the other side. I showed the dealer and they offered to take it to the shop and see what they could do. But that would take a while.
In a couple of hours, I made two new stabilizer levers that were re shaped to avoid those conditions. Problem solved. The control valves are just too close together with no room for error in the making and positioning of the control handles.
Originals on top. Soaking the originals in boiling water allowed the rubber tips to slide off and get placed on the new handles.....after they were painted black, of course.
Below is the original configuration. You can see how close the rubber boot is to the outrigger levers even with the control handles sitting in the "neutral" position.
RichardAaronlx2610
Aug 3, 2021
441
490
New Jersey
Very nice! I bet That’s what my out riggers are getting stuck on as well. I didnt Bother to look at that issue yet. Was saving that for Sunday. But i bet thats it. Thanks for the info man
