bx tractorjoe
Jun 3, 2020
258
140
loxahatchee flordia
Been awhile since I've done much with my l2501.. now at 104 hours..
Today I forked this stupid pointy poky palm thing that I hate that cut me a few times. was very hard to clear weeds around it, and mow near it as it stuck out 3 feet.. got me for the last time yesterday when I mowed..
So I put the forks about 5 inches apart and tried to get under the roots and pull it up...was lifting the back wheels off the ground.. so I got the forks under the roots and drove forward while pulling up a little till it popped out.. take that you sob!!
Reactions: 10 users
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
Big day for me with the tractor :)
The promised delivery of my Wicked 55 grapple actually happened.
I was thrilled that my hydraulic plumbing worked! I ran lines from my 3rd rear remote to loader. No runs, no leaks, no errors.
Need to grease everything and trim up those hoses. At the same time all the implements I used on the lawn project had to be put away. The tiller is being stored inside in my basement garage. I had to make room for it and still be able to get my (new to me) snow blower out. Will need a couple more furniture dollies but ok for now.
So many projects, so little time!
Reactions: 14 users
S-G-R
Grand L5460
Jun 17, 2020
1,353
3,133
PEI Canada
Put the forks on and boxblade for ballast and took it to work and moved a lot of pallets. Much better than a hand cart.
8,810
That is awesome! I like the orange and the new hose routing. I like the lab too. :D
bird dogger
Vendor Member
Feb 24, 2019
1,693
1,613
North Dakota
Rototilled the corn patch today after the flail mower had chopped up the stalks and residue. All went well while tilling the actual corn rows.
However…..On one end of the field, contractors had been burying fiber optic cable along the road’s ROW which was right on the inside edge of the field. Their mini ex and bobcat had compacted the ground so hard it was like a rock! Only a couple passes on that end with the tiller and it suddenly stopped tilling. Oh, oh! And yes, the slip clutch was set and working as my tilling speed had to be adjusted when the slip clutch started to slip while tilling the corn rows. The PTO shaft was turning but not the tiller’s shaft with the blades. Sure glad I didn’t start tilling the field’s headland first.
Back to the shop for a tiller autopsy. Hoping to find a shear pin or soft key sheared. Nope! The splined stub axle for the drive gear was inserted into and joined to the round tubing shaft with the mounted tines with a bead of welding from the factory. The poor weld had finally broken loose and the stub axle would spin in that hollow tube. It looked like only a couple of spots had the weld actually penetrated both the splined axle and the tubing. Guessing the poor weld had deteriorated with rust/moisture over the years and finally let loose with the vibration in that extra hard ground. Hart to believe it’s held up all these years.
Howard Rotvator_LI (3).jpg Lower Splined Shaft.jpg Splined Stub Shaft.jpg Poor Factory Welds.jpg
I’m hoping that complete shaft can be removed without taking off all the tines. Or maybe just on one end. It’s going to be a little bit of work to prepare for a few minutes of welding. :(
8,810
View attachment 66146 View attachment 66147 View attachment 66148 View attachment 66149
What a nice field. Sorry to hear about your problem today, but as you said, you had many years of trouble free use. I bet your repair will be better than factory and you'll get many more years out of the rototiller.
bird dogger
Vendor Member
Feb 24, 2019
1,693
1,613
North Dakota
Thanks! Yeah, the Red River Valley has some pretty nice soil. In this spot the rich black top soil is close to 2 feet deep.
This tiller certainly doesn't owe me anything. A few years ago, the original gears and chain finally wore out. No replacements. So I found some weld on hubs and flat gear to match. A little machining on my little lathe had the gears matched to the hubs and back in business. this repair should have it running for many years again and it will certainly be better than the original welding.
Since the wife is gone for the weekend, I could've spent tomorrow sitting in the shade with a cooler of beer. But now I have something better to do! :ROFLMAO:
David
PaulL
2,569
1,534
NZ
Surely you wouldn't waste alone time by fixing things. Drink the beer tomorrow, fix the tiller when she's back....
GrampaJeff
L4060Hstc-LE
Sep 15, 2021
Wyoming
Cleaned up the side of the house a little. What’s NOT shown is the previous owners cluster.. of a wood framed greenhouse and 4 million weed/plants. Put in a pad for the new shed as well.
clarksvilleal
LX3310, LA535, BSS65 Box Blade, 6' Landscape Rake, Wallenstein BXM32 shredder
May 28, 2011
14
29
Maryland
Installed 3 Bolt-On hooks and clevis mounts on my LX3310 60" bucket:
Reactions: 7 users
D
Deleted member 47704
Guest
Started taking tractor apart to add cruise control and tilt wheel.
bird dogger
Vendor Member
Feb 24, 2019
1,693
1,613
North Dakota
Paul, your advice was spot on…..so I took it. What a boring, uneventful but fine day it was!
Reactions: 8 users
bird dogger
Vendor Member
Feb 24, 2019
1,693
1,613
North Dakota
Who's the artist for the fence/gate painting? Very nice, indeed!!
Crash277
BX23S
Jan 17, 2021
844
621
Final roll of the driveway. I hope. This roller is a neighbours. 3’, I think if I buy one I will get a 5’
Reactions: 6 users
S-G-R
Grand L5460
Jun 17, 2020
1,353
3,133
PEI Canada
Done for now. I need some gravel for another project and what's left I'll use to build up the right side of the shed.
Reactions: 7 users
