OrangeKrush
Nov 15, 2020
1,044
516
Indy
Finally got around to puting on my Piranha tooth bar.. fit was perfect and I'm ready to use this thing! Having some dirt brought in to fill a lot of voids, it's what I ask for.. for Father's Day. 😊 29C1C135-20CB-407F-B2CA-DE194E3729DB.jpeg 782BD73C-978A-4CCE-9CBC-6FB72B94C891.jpeg E853AAC6-E4F5-4732-9616-82C2918DA3C7.jpeg
Very sharp! Going to make work so much easier on the lil guy.
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
I was mowing the back field the other night and hit a tree root. I sounded funny and was skipping the center so I parked it for the night. Yesterday I got under it and found 3/8" of wobble in the blade. I got the nut off (left hand BTW) and it's a mess and looks like it sheared. I started breaking down the deck and discovered some chuckle head had put a grade 5 bolt where the shear pin connects the PTO to the gearbox. :mad: I was not a Merry Man yesterday. I'm getting to old to be wrenching all day and am very sore today, but thank God for hydraulics. If a new bolt will work it'll be a bonus - if not it'll be a new spindle. A trip to the tractor place Monday is in order.
johnjk
Apr 13, 2017
1,619
1,658
West Mansfield, OH
Replaced the drive belt on the mmm. While off i greased everything I NL using those hard to reach fittings on the PTO shaft. and cleaned the bottom of the deck. Also put an edge back on the blades. Worse part is getting that shaft back on. Had the wife help push. Time to grab some water and a cigar to mow. BA01295E-9CA8-44C2-9705-A8DBFCEA7544.jpeg 262B3E56-D97E-4A57-BF29-F821F4E2A357.jpeg E3DE7D1A-E4FD-485E-B46B-6029705E0FBC.jpeg image.jpg
6,867
Mowed last night and temperature gauge was a little squirrelly to the hot side.
Today, sprayed radiator out with garden hose, and then greased the mower deck.
Also cleaned spade connection for temperature sending unit. Seems better.
I don’t think it was getting hot, but like motionclone’s message in another thread yesterday, always start with the simple stuff….
Last Saturday was the’Moline’s turn for attention. Still covered this weekend.
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Loading up for Monday's job:
(there's a B2650 buried in there!) :)
60' of 12" culvert to lay
498 retaining wall blocks rto place for a 2 car parking spot on a sloped hill
75 miles away!
Reactions: 6 users
3,093
Keep us informed with lots of pics!
MDCobraMan
Kubota L3430 Grand Open ROPS, L3430 Grand Cab, F2400
Jun 8, 2021
27
Yes I did try that green slime. That's what is so disheartening about it. Now, in the cold I have to jack it up, take the front wheel weight off, remove the wheel and then put a tube in. Already had to do the mate back when warmer. Figures one of them would catch me. I used almost a whole bottle of slime but wonder if the FWA causes the sidewall to flex to much to stay sealed. I'm not sure in my own head that it's a fair comparison or not. A 2wd tire doesn't have the same forces exerted upon them.
I use the rim bead sealer on my equipment tires. You can break the bead and apply it around the bead area with the included brush. It's available at most auto part stores. Just wipe the tire bead and rim area with a good cleaner first. Works great, cheap and fixed most of the slow leaks I had. The slime seems better for tread area leaks but not too good for the bead unless you add a lot into the tire.
Wayne
MDCobraMan
Jun 8, 2021
27
I moved my F2400 out of the way then finished mounting the backhoe frame to my L3430. Now it's on to the hydraulics.
Wayne
S-G-R
Grand L5460
Jun 17, 2020
1,353
3,140
PEI Canada
Bought a used trailer from my dealer they used for deliveries. I'll pick it up later next week. Mowed 6.5 acres of grass with my 60" MMM. 4 acres of it is my brother in laws that I took on last month. I think I will pick up either a 72" or 84" rear finish mower if it's going to be a ongoing project.
4,846
Moved some scrap (that’s been laying in the woods since some long dead person I’ve never met left it there) into a pile where I can get a truck and trailer to it once it’s all piled up and ready to go to the dump. It’s a lot easier to wrestle an old oven away from a herd of honeysuckle vines with a grapple than it is with just a pair of hands.
Driving down one of the trails, found it blocked by a large maple limb. Old method: go back home, fill saw with gas and oil, back to the obstruction, cut to manageable pieces, drag out of the way. Approximate time, 30 to 40 minutes. New method: run into it with grapple, lift slightly, shove it into the adjacent underbrush, back up to re-enter the trail, on to something else. Approximate time, 30 to 45 seconds. I like the grapple.
Reactions: 6 users
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,561
2,023
Western MT
Ran the grader scraper on the neighborhood gravel road past the point that is maintained by the county. At this point, the “unmaintained” part that we maintain is better than the maintained part. :D
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
If we learn by our mistakes I'm going to be one smart guy someday. . .
I got to use my subsoiler today.
I have 5 wired cameras in about a half acre of the woods to record the various critters that wander through. When I did the initial install BT (before tractor) I just put the cat 5 and power cables in pvc conduit and laid it on the ground. Within a year they were all covered over and out of sight. Now I am looking to extend the system another 300' and use the power for led lighting along the driveway. Burying the cables is a much better option.
The subsoiler went way beyond my expectations in digging a narrow 12" deep trench. It had no trouble ripping roots and pulling out some good sized rocks for the 120' or so that I was running to another tree. There I would split out the power for the leds and have a small ethernet switch for the new cameras another 200' beyond.
Unfortunately when I turned around for another pass the blade snagged the existing conduit feeding those cameras.
Both the cat5 and power cables broke. I guess they were no match for a 3000lb tractor moving away.
Boy, I am going to be the smartest person someday!
OrangeKrush
Nov 15, 2020
1,044
516
Indy
I guess you were right., the existing conduit covered itself pretty well. It happens to the best of us, your mind gets to wondering and takes over for a short time. Some may call it daydreaming but for us to do guys.. we usually have multiple task that needs done Now! Always thinking of the next step..
BigG
Sep 14, 2018
1,951
773
West Central,FL
Seams to me going from a 60 inch mower isn’t going to gain you very much.
Take a look at tow behind mowers like a Swisher. You could cover about 9 feet in one pass.
Look at some YouTubes. I have used one and like it a lot.
B737
LX3310
Jun 9, 2019
2,022
2,204
Put some time on the flail mower today at home. For some reason the woods on one side get full of overgrown grass and weeds, while the other side just gets little saplings. I'm really happy how the flail mower can do a halfway decent cut on the grass and still be brought through the saplings and brush.
Reactions: 6 users
S-G-R
Grand L5460
Jun 17, 2020
1,353
3,140
PEI Canada
I'll check them out. Thanks!
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
335
554
NH/VT NEK
We took a long weekend to go camping which meant moving the Hawk horse trailer out of the way to get to the travel trailer and then putting the Hawk back in place and moving the Winnebago back in place upon return.
I used the receiver mount in the pallet fork frame (one of the reasons I got the forks) and one of my adjustable hitches for the truck.......horse trailer was a breeze.
Then when we returned I pulled the Ram down the driveway with the TT and just dumped the TT, pulled the WDH and grabbed it with the tractor and flipped it around and backed it in without issue.
The empty hitch weight on the TT is 420lbs so loaded I was probably only in the mid 500lbs range.
The 2601 did great......put in Low, 4WD and went slow. The key was really going light on the stick to keep things moving slowly and gently with the hydraulics, as you can really whip the trailers up and down pretty good with full speed on the stick.
Success.
Today, 2000lbs of flooring drop shipped on pallets at the top of the 550' gravel drive. We will split it up into 3 pallet loads and bring it down to the house.
Crash277
BX23S
Jan 17, 2021
844
621
I love it except........
Don't put your chainsaw in the bucket and forget that it is there because.....Bad things can happen. :rolleyes: :(
I forgot a chain in my bucket once . Sure enough I filled the bucket with dirt. Didn’t see the chain till I dumped it.
