5,225
Finally got the WC68 up and running today. Took longer than 2hrs to setup I think, but part of that was because I only had a hacksaw with a well-worn blade to cut the PTO shaft. Did one half, then came back with the sawzall on day 2 (we live an hour away from our property until the house is done..hopefully in a month or two). Sadly, FedEx managed to beat up and bend the metal crate (and do some damage to the chipper, but it appears to just be cosmetic/paint). Not sure I'll be able to make a dolly out of it.
Question for folks familiar with the single infeed roller chippers -- for larger branches (maybe 3" at the base?) it just "hops" on it and won't actually grab it. I assume I need to adjust the infeed roller spring and was thinking I need to loosen it. Is that the right approach? or is there something else I'm likely doing wrong?
Excited to be able to chip rather than burn the branches. Have so many future uses for the chips!
About the hopping:
1) Like Old Paint said, if there’s a taper on the end that helps.
2) If it’s square cut on the end and hopping, lift the back (the part you’re holding onto) up to the top of the chute as you push forward. That puts the square edge at a bit of an angle and if you can get a tooth to grab that square edge, the roller will climb the end of the limb as it pulls it in. Once you get it to catch, you can help it by pulling down a bit on the limb while pushing forward to lever the roller up. When the limb is down on the bottom of the chute and feeding by itself, let go before the knives hit and rattle all the bones in your arms. That process takes about 1/10th the time to do as it took to read all that and it’s kind of all in one continuous motion with some practice. After you’ve done that a while you’ll get good at it.
3) Not always, but often you can plan your feeds. Ideally, don’t start from nothing to a 4” square cut branch. Put a 2” or 3” branch in it and start the 4” on the heels of the smaller branch before the smaller one finishes feeding so it’s not all the way down when you start the 4”. If you don’t have that ideal stater branch but have a bunch of little stuff, put a wad of little stuff in the chute and use that bigger branch as a ramrod to stuff it in. That wad of little stuff will open up the roller and ease feeding of the big one when the wad of smalls is half way or better through.
4) At some point, it will jam. 90% of the time, reverse a couple inches, back forward again. No need to wait or be polite about it: bang, bang back and forth. Do that until it clears or about 6 times whichever comes first unless it’s just obvious you miscalculated and have to back it all the way out to trim an offshoot to get it in the throat. Even then, a lot of times you can back it all the way out, rotate to get a better angle on it, and re-feed without trimming.
5) If you have a relatively straight limb without offshoots so it won’t hang up on a backward feed and it’s one of those where it’s 2” on the little end and 5” on the big end, there’s nothing wrong with feeding the 2” end first.
6) If there’s a chunk stuck between the knives and the feed roller rattling around making an awful sound, just shove some more stuff in it to clear that out.
7) If it starts making weird noises or looks kind of like it’s smoking but isn’t on fire, shut down the tractor, open the clamshell, and check the discharge chute (which is probably clogged). You’ll need some sort of wrench to remove the one bolt to do that. A decent sized straight screwdriver is handy for cleaning it out; wood chips packed by a tractor can be impressively dense. Chipping sticky sappy stuff such as green evergreens can clog the chute if feed speed is excessive. Slow feed speed if clogging.
There’s a technique to feeding a hydraulic feed chipper. I have probably 75 hours on my single drum WC-68. I have several hundred hours feeding a twin roller 12” capacity commercial unit (which was owned by my then employer). One roller, two rollers; technique is pretty much the same and neither is going to go from empty to a full capacity feed without some effort, practice, and skill on the part of the operator. Nothing at all against twin roller units but I don’t see much difference in practical performance with the single roller. Of course the only two I’ve spent much time with are the WC-68 and an old 110 HP twin roller something or other (it was white and had a JD engine) from the late 80’s so possibly the big white double roller thing was a big POS but I don’t think so.
Edit: And as a general rule, feed from the left side. The rotation of the knives knocks the limb to the right if it knocks it anywhere so if you’re standing on the right side of a limb you will eventually be struck by said limb as the chipper slams it into the right side of the chute. Allowing your tractor to strike you in the leg with the equivalent of a baseball bat is not recommended.
GrizBota
Apr 26, 2023
1,147
732
Oregon
New member, first post. New L3902 arrived over a week ago. Have 10+ hrs on it now. This past weekend, cleared some of fence posts piled up and over grown on my property. Almost 8 years of looking at the mess, made easy work of it with the pallet forks in minutes.
First new tractor. Replaced a 73 yr old John Deere A. Will mostly use for brush cutting, building and maintaining a dirt bike track and trails. Love it so far! Got the BB2566 box blade and it's my favorite attachment so far.
Congratulations!
Surprising how nice a modern hydrostatic transmission is after coming off decades old iron. My Ford 8N is about 73 years old too. It’s sat since 2007 when I got my L.
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
Welcome sir!
5,179
Congratulations!
My 8N is 72 years old, and has sat for 9 years now.
Will be up for sale this weekend (July 4th).
I have owned it for 50 years, but it is time for it to go.
Has Sherman transmission, so hopefully will bring a good price.
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
My NRCS rep did visit my farm for a final inspection of my work. I passed. He did note that I was getting some root sprout Locust trees (which I knew & plan to address). Said he had a mix he would send my way that would kill anything except Cedars. The rep has been a pleasure to work with. His expertise has helped me. I did struggle with time lines (read - deadlines) that were imposed. But he worked with me & the project is complete. We both signed the papers & now I just wait for the 💰.
How to Master Cedar
I'm glad you got a good rep. Mine is lazy and full of 'I can't' excuses, until I talk with her boss, the regional representative, then stuff happens.
Yes that regrowth is a PITA, especially for me, the invasive South Texas brush is relentless and it never ends.
GrizBota
Apr 26, 2023
1,147
732
Oregon
Dad brought the 8N I have home in 1976. It’s the first thing with 4 wheels I ever drove, 47 years ago. Hope you get good price on yours. What I’ve seen is $1500 to $3000. The $3000 ones are the $1500 units that someone has spent a few thousand on to restore.
Chanceywd
Mar 26, 2021
730
675
central ny
My 8N is a 1950 so 73 too and it hs the sherman over/under/direct. But I use it a lot still especially when the backhoe is on the L2501. I have welded up a 3pt to ssqa so I can use my LP forks on it so much handier to move a pallet as I can see it there vs front of loader. It is usually parked after the l and I just start and use for somethings and don't have to wait for it warm up like the diesel. It is also my snow plowing tractor with a power angle plow for the front. My son and I built a roller recently and the 8N was there to move it around using the drawbar. So I plan on keeping the N for sure. I figure I will give out before it does.
Bill
g_man
Feb 3, 2023
293
1,328
NE Vermont
As usual we got a bunch of fir blow downs over the winter. They're spread around not concentrated. I've started to pull out any that I can make a stud log out of - 12' -6" long minimum and 6" diameter minimum. I went for these two the other day with the M5640 and winch.
I stuck the camera up on the ROPS - so there is a little vibration. The video ends prematurely when the camera battery dies while pulling that lower tree off of it's stump. I found it pretty interesting what the winch cable did during that pull - something I've never seen before.
gg
5,179
Bill
With me being 82, and my 8N being 72 (rebuilt engine), I am virtually certain that, "I will give out before it does".
I simply don't need or use my Ford 8N, since I also have my beloved restored 32HP Ford 1920 FEL, (power steering is a wonderful thing ), and a Kubota L48 TLB.
After 50 years of my ownership it will be kinda sad to see it go,.......but it is time.
The cash will go toward grandson college expenses.
pokey1416
Jun 24, 2020
567
844
SW Michigan
I finished up cutting my friend's field this morning. The weather was nice even though the grass was still very wet and thick in places. I'm amazed by how fast it was this year using the M6060 and the RCR1884 in combination for the first time. The M6060 is a very comfortable and capable tractor and it makes this sort of work very enjoyable.
The big problem when it's wet is that the wheels flatten the grass and it doesn't stand back up again so I'll have to run around the field in a few weeks when I'm back home to take care of the stuff that escaped this first cutting.
Did you notice a difference with the front weights? Been thinking of adding some to mine for when I have the loader off.
Trapper Bob
Jan 17, 2022
446
818
Andover, KS
How to Master Cedar
Thank you for the resource. I have some prickly pear that I will work on too. You can’t have to many weapons when you’re trying to kill stuff (not trying to offend the kind hearted).
My NRCS rep is the supervisor (lots of experience). It is nice to ask questions & get answers as well as helpful suggestions.
RichardAaronlx2610
Aug 3, 2021
451
507
New Jersey
Working on my Rc crawler course and keep getting hit with pop up thunderstorms thankful for a cab right about now lol
pokey1416
Jun 24, 2020
567
844
SW Michigan
Are your tires filled?
No, I have the backhoe on all summer and Kubota doesn't recommend filling tires with the BH (maybe backend becomes a little overweight) so I only use the 3PH in the spring and fall, oh and winter. I have the R-4's and so far they wear extremely well and don't rut up yards too bad.
Chanceywd
Mar 26, 2021
730
675
central ny
I have had my 8N for about 25 years. I like the size and that is why I bought the L2501. Mine is 73 and I will be 70 in about a week and a half so the 8n is my elder and I have to respect it for all it has been thru.
Bill
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,526
3,712
PEI Canada
Mowed grass again. Our weather has been terrible but the grass keeps growing. Noticed the FDR2584 wasn't leaving a uniform cut so I pulled the blades to sharpen. I had ordered new blades a month ago but so far only one showed up.
9,575
It's definitely a much better view out front mowing with the loader off, and the tractor and mower didn't feel bouncy at all. I would say that the balance and ride with loader and no front weights is comparable to front weights and no loader. The main reason for my removing the loader is to reduce stress along with wear and tear on various components while running up and down the field. I also hoped that I would be able to fit the tractor and mower entirely on the trailer but the tongue weight is excessive with the tractor all the way forward.
I'm over in England visiting my brother, and front PTO and 3-points are common on tractors over here. The Del Morino flail that I have is set up to be run on the back or the front of a tractor with input/output gearbox shafts. It sure would be awesome to have a mower of some sort out front.
9,575
The farm here has an LX-401 set up with front weights and an hydraulic offset flail that they've been using to cut the embankments around the lanes.
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
There is a farmer a few miles from me, he has 2 big tractors( probably 100hp+) with front mowers. During the dry months, like now, I have seen the tractors in action mowing and pulling a rake behind in the hay fields.
