5,181
Ditto....I bought one of the 18volt Ryobi ones at Home Depot last year and it is one sweet tool.
It is just so easy to pick up that battery powered gun any time, simply pull the trigger, and add shots of grease where needed.
( lock-N-Lube included).
bird dogger
Vendor Member
Feb 24, 2019
1,720
1,670
North Dakota
We had 8 to 10 inches of heavy wet snow overnight just waiting to challenge the snow removal equipment today. The "Snowbie Wan Kubotie" took care of it easily. I wish it was colder than the 25° F out as the Jegs heater kept the cab a little more than toasty warm......even in shirt sleeves. A nice problem to have. :)
Reactions: 6 users
WAS BANNED FOR NSFW PICS
5,157
Dusty pull the bowl off the bottom of the carb and give it a good cleaning. Pull the feed hose to the carb and blow through it, Probably something lodged in the needle and seat.
Once I got the piece of wood out that was jamming up the governor, I quit for the night. Staying up till 4:00 AM reading the factory service manual, all 400 pages, and trying to find diagrams in the parts manuals, I finally went to sleep. In the morning, I went back to the chipper, and it started right up, but oil was all over the muffler. couldn't figure out what was leaking, until I noticed the dipstick was not fully seated. Two cans of brake cleaner, and it was cleaned up. Restarted the chipper, and waited till the oil burned off the muffler, and then drove the tractor and chipper back to the limb pile. Pushed the throttle all the way to the limit, and it chips like it is new again. I put the chipper back into its corner in the canvas garage, and after I unhooked it, I remembered that I wanted to add a fuel shut-off on the line from the tank to the carburetor. I will be pulling it out again in the morning to do that quick project. Right now it is snowing, and the snowblower has yet to be mounted.
Thanks for the suggestion about cleaning out the bowl, but just getting that carburetor off is a major task in itself. It is a Kohler Pro 27 twin-cylinder with dual overhead valves. I also put out 3 different types of mouse bait, and hopefully, the squirrels will also avail themselves of the free food!
5,970
Started digging in a wooded section for the next run of new waterline. The first part of the job went like this. Not one rock over 2" in diameter.
Here's what was on the menu for today...approx 2 feet wide by who knows how deep?
I was able to run down the side of the foundation and hit another wall and slab floor. Gave up for today. Gonna need a bigger/rental machine. No way I want to trash the new mini on this...
orange crusher
BX 2680
Sep 30, 2017
354
482
ontario canada
Next comes the heater!
No, don't want to frost it up inside. I have a 12v plug in heated coat I wear which keeps me very comfortable. I just wanted this to keep the wind and snow from pounding me in the face. This will do that and the cost was reasonable ($845. canadian) Will take about 20 minutes to take it off the tractor come spring.
Crash277
BX23S
Jan 17, 2021
844
621
Got the snow blower on. I love having the QH. I used the ssqa-v today to put a sawmill into the shop. Gonna have to brush the snow off the truck this week. Needs some work but not much. Just maintenance items and 2 small bearings. Got 4 cedar logs to start learning with. Hoping to cut enough lumber this winter to be able to build the BX her own little barn.
Crash277
BX23S
Jan 17, 2021
844
621
What year model is that Wood-Mizer? Gotta be pre '85.
All I know is her dad bought it brand new and called it the original woodmiezer that made them famous lol. Honda 20hp engine runs, I’m gonna change the oil and plug just because I don’t know the last time it was done. the original extension section is available too if I need it.
Crash277
BX23S
Jan 17, 2021
844
621
This was yesterday’s task. Random request from a neighbor about 20 min away by bx... in the spring he will be getting more fill and i will be completing the garage entry along the entire width then topping it off with crush.
5,281
I don’t recall the last time it rained here. As dust dry as I can remember in at least 3 years. Rain possible later this week so this weekend was a little bit of a scramble to get the gutters blown and leaves up at the three houses, leaves raked off the gravel road/driveway and rocked trails. First time we touched them this year so there were a LOT of them. The pine straw rake and grapple did a good job moving large quantities windrowed by the mower. Grapple works better with wet leaves; still worked pretty well with dust dry leaves. Not much time on the Kubota for that day and a half job but still an important part of the process.
While raking the foot and a half of leaves from the front of Dad’s pole shed, I barely bumped the door jamb for one of the 9’ x 20’ sliding doors with the back of the grapple as I was backing parallel to the front of the shed. Really didn’t even feel it, but noticed the door suddenly slide open about 4’. Noticed the jamb didn’t look quite right as it seemed to be a bit separated from the phone pole corner post but it was still upright. Then, like a felled tree, it slowly fell over. 🙄 About $25 worth of lag screws and door latch should fix it. Latch is already replaced. Didn’t have time or enough 10” x 1/2” lag screws for the door jamb on hand so that can wait a day or two.
Before possibility of rain, needed to finish getting up the wind fallen tree in the creek bottom we started on a couple weeks ago when our son was home. There’s a pretty reliable mud hole between the wood yard and tree that’s currently dry enough to cross with a load without getting stuck or tearing up the place. A horse could take a leak at the head of the cut and you probably couldn’t walk across the mud hole at the bottom for a week so the remainder of the tree needed to come out before the potential rain. Cut into 7’ logs to haul to the wood yard for processing later. Had 20 minutes of light left when the last load came out.
Overall a productive weekend. Would have been better if I hadn’t hit the shed but I suppose $25 and about about an hour labor isn’t anything to get too wound up about.
I didn’t measure the diameter of this white oak log. It’s 7’ long on a 72” grapple. 28” saw didn’t go all the way through it so more than 28”. Guessing 32” to 34”. It was all the tractor wanted but low and slow it traveled fine and stacked at the wood yard with no problem.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
OK, it could possibly be an '83 which was their first year of manufacture. That or an '84 model. ;)
That is amazing. (y)
Could you send me a couple of pictures and I will research it.
5,281
I would send that log to the sawmill and then stack it in the barn to dry.
It, and the other five like it from that tree, would be good candidates for that. Used to mill some of our trees into lumber back when I made furniture for us and enough custom work to at least pay for whatever tools I had. We didn’t need more furniture and the custom work got to being a job I didn’t much enjoy. I haven’t made anything in probably 10 years. Still have enough white oak, red oak, hickory, and eastern red cedar in the top of the shed to make quite a bit of furniture if someone was inclined to do so. Can’t recall if there’s any persimmon left up there or not. Still have some framing sized pine up there as well, although that’s getting sparse.
Edit: BTW, I really like the white oak for kids furniture. Hard to carve with hand tools but machines well and so dang hard a 8 year old can beat on it with a hammer and never put a dent in it.
5,157
I was thinking it would make some great flooring. I would love to have a floor of sugar maple and red oak.
bmblank
Mar 4, 2015
738
434
Cadillac, MI
I blew 10-12" of snow out of the driveway and private road. All in all, probably put 2 miles or so on the tractor/blower. Last night after getting the kids to bed. Was out until 10:30 or so - big ol' LEDs on the ROPs sure are nice.
I just wish the road commission was any good. More than half of my drive this morning to work (albeit short) was completely unplowed. They managed to get some of the corners, but then lifted the plow once they made the turn. Can anybody tell me why they would do that? My only thought is maybe they travel faster without the plow down and they're trying to get all the corners/stops first before going back for the rest of the road. Seems like it wouldn't be worth it, though. Just flabbergasts me.
5,281
No clue. We don’t get the snow y’all do but if they’re on the road and there’s snow on the road, the plow is down. Only time the plow is up is if they’re traveling from one area to another on an already cleared road. Don’t think they could go any faster without breaking the speed limit everywhere except the 65 and 70 mph zones and sometimes those too if it’s light snow.
forky
Feb 23, 2021
310
333
Wisconsin
How do you like your rear 3 point blower? Is that model you have listed Landpride?
I'm planning on one in the future, and curios if you are happy with yours.
DeepWoods
B2650HSDC Woodland Mills WC68 Wood Chipper
Apr 10, 2019
342
282
Bigfork Minnesota
Spent the day blowing the 6 inches of snow we received. Had a doe standing in the woods on the trails I keep open for my wife to walk our dog. She never moved,
even after I took several photos of her. They don’t seem to be bothered by the tractor running at all. I’ve even had them walk towards me at times while in the tractor. When I was done at our place I went down to my neighbors and made some quick cash blowing out his drive
