fast*st
M7040, L2900, F550 ford, Yanmar vio70 excavator, Case 580, JD 350 dozer, JD 644E
Jun 26, 2012
172
Northern Mass
Today I got my forward 20" and rear facing 12" LEDs mounted and wired up.
Hey on those LED's how do you like them at night? we have a 7040 where the dealer put some cheezy oval halogen lights on the top of the cab facing forward and well, the light output is pretty dismal, the headlights do a nice job but wondering how the LED's perform in your observation.
CFDWheeler
57
Grant Co, Ky
Honestly, I haven't even tested the tractor lights at night yet, but I run the same lights on both my Polaris Ranger and RZR, and they are flat out BRIGHT! They turn night into day. It is incredible how much light they put out, and they are getting cheaper every week. Best mod you could do to anything you operate at night. Side facing lights are next, if I ever feel the need for them.
BearBIA
"07" MX5000 4WD
Apr 5, 2014
Mansfield, Ar.
I finally finished bush hoggin a 40 acre paddock. It took me 40 hours....never been used as pasture, trees were cleared about ten years ago and then ignored. Lots of rocks, stumps and old barbed wire. I'm on my second cutter BTW... I love my Kubota, after the 240 hours of abuse it took with my idiot brother in-law, I really can't see getting anything else. Oh, Tractor's name is "BUDDA".:D
4,385
I PAID IT OFF YEAHHHHHHH,, now time to looking at a new one,,,:rolleyes:
Donystoy
Dec 10, 2013
683
309
Binbrook, Ontario
Just replaced the hydraulic pump on my backhoe. For some time I have had to have the PTO on high speed and engine RPM's over 2000 to achieve normal control. Just like brakes on a car. They loose efficiency so gradually that you only realize how bad they were after they are replaced.
Justacafe
L4310
Apr 5, 2014
14
Madison, wi
On my L4310 with just over 2000 hours, I changed the transmission fluid today. Everything went fine, except the left side (suction?) filter will not loosen up. Both the new and old filters have little notches at the end that screws in. The old filter is so tight, and I've tried everything including the standard filter wrench.
Any suggestions? Thanks!
Skip44
Jeeps, L2900, FEL, tiller, brush hog,post hole drill, rock rake
Feb 19, 2014
116
Alexander, Maine
Did you try a strap wrench? I have one with a rubber strap that works magic.
Skip
Justacafe
L4310
Apr 5, 2014
14
Madison, wi
Skip
Thanks.....I have the 'standard' metal wrench that's always seemed to work in the past on my other vehicles. I'm going out today and get both the 'strap' and the metal chain wrench at Sears. Might have to use a small length of pipe for leverage.
Skip44
Feb 19, 2014
116
Alexander, Maine
I wish that I had seen this earlier, Sears is where I got the strap wrench with the rubber strap. Either way let us know how things work out.
Skip
The_Al
L3540, Heavy duty FEL, 9' bachoe, Brush hog, 72" grappler
Jul 19, 2013
154
MA
I finally got to get out the garden area, and ripped out the remaining bushes. Was smiling ear to ear the entire time riding.
One thing I hate more than shoveling snow is raking (the front lawn). There has to be an easier way, but it is pretty small area (<10k sqf).
buckaroo52
Kubota L 3800 DT
Jun 5, 2013
102
Molalla, Oregon
I pushed 65 tons of pit run rock over an edge today, filling in a sloped hill to make a 35 yd. pistol range. This is the 28th. dump truck load i've pushed out, and after today it looks like I'm going to need at least 12 more loads. Good thing I work for a rock quarry about 200 yds away...
Stuck oil filter ? Slam your biggest screw driver all the way thru it and twist her off !
9,469
Send some of that rock my way I could use it! ;)
And I'll second the screwdriver method! :cool:
Skip44
Feb 19, 2014
116
Alexander, Maine
Justacafe, yes I have done the same thing with a hammer and a chisel on stuck bolts/nuts. I have also used the "drive the screwdriver through" the filter method. I don't like using it because I have had the end of the filter rip off. Also you can introduce foreign material into the oil system. Of course sometimes you have no chose. So you do what you have to.
Skip
kc8fbl
2014 L3200 HST FEL, 1949 Minneapolis-Moline R
Aug 23, 2012
222
Gobles, MI
Not much on working on the tractor today, but went the open house today at my local Kubota dealer. Lots of fun, food, and of course, tons and tons of orange! Here's some pics of it!
