Fatfenders
LX2610 HSDC, LX2980 64" Commercial Snow Blower, FEL w/60" QA bucket, BB1260 Box
Dec 1, 2019
60
36
Tomahawk, WI
Barely made my LX2610 sweat. Pulled my Roll A Dock out of the lake for the season. New to this home and was told dock had not been removed for 13 years under prior owner. Obviously they didn't have a Kubota!
6,185
stump removal. not much fun. :(
bx tractorjoe
Jun 3, 2020
258
141
loxahatchee flordia
I used the l2501 to pull my 15 kw onan rdjc diesel generator down to my fence along with the welder to weld a gate that broke due to being poorly welded with not much penitration.. it pretty much just poped off taking the weld with it..
L35
Jun 13, 2010
642
705
CT
Hydraulic fluid and filter
Oil change and filter
Flushed radiator and new coolant
Fuel filter
Pressure washed
1166hrs
6,185
...created a whole bunch more work for myself. Since I've taken so many trees down and ground the stumps, I feel like I need to put some back...and so it starts.
and the rest of them here....
my plan tells me that I should have my head examined.
Reactions: 8 users
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Cleared out a spot for a well/filter house for a customer today.
wgator
L4701HST, FEL and other stuff.
Jul 28, 2018
482
147
NC
How far away was it from septic system? In my neck of the woods the well has be be at least 50 feet from septic. I am on both.
fj40dave
Sep 24, 2009
425
257
Yelm, WA
The septic drain field in on the other side of the area in the picture where the forms are set for the modular home foundation.
7,116
In Bandera County Texas separation must be 100'.
Also can't have both well and septic on lots of 5 acres or less.
Wow, interesting limits..... with just a 100’ separation, it’s odd that both can’t exist on a lot less than 5 acres.
In New Yorkistan, for some types of sewage systems such as dry wells, minimum separation is 150 or 200’ to a well; 100' is allowable for conventional leach fields with normal absorption trenches.
Could certainly be an issue of geology/soil types you have in Texas.
7,116
Put the steel on, as my father would say. Better to do it at 60 degrees than 30....
Probably service the blower and hook it up shortly. Don’t have much dirt work to do with the loader.
Surprises me at how much the chains have stretched over the years.
Often asked this time of year...I do NOT use wheel spacers, although many do.
I just make sure the chains are tight, and "cheat" them a little to the outside of the tire...
6,185
Got 20 of the above trees installed today. Round 2 tomorrow. Not looking forward to it. When I had the landscaping business, I always disliked day 2. Although, maybe it really wasn't so bad because I was being paid to do it then? ;)
This job will certainly spill over into day 3 for sure. I have to take it a bit easier these days. I do not want to have to go back to the surgeon to repair hernia mesh.
Oh well, my front yard is looking like a boreal forest.
You guys with B2650's and a hoe...do you have trouble staying planted when running the backhoe? I have a difficult time getting anchored. I was thinking of maybe picking up a 12" bucket. I think the 16" puts a lot more pressure on the hoe before break out and I don't have the weight in the tractor to keep me from sliding towards the hole. Just curious.
wgator
Jul 28, 2018
482
147
NC
Think of the options. You could be sittin on couch suckin chips and beer or you could be using tractor to plant trees. Use common sense and continued success planting remainder of trees!
bird dogger
Vendor Member
Feb 24, 2019
1,741
1,714
North Dakota
I have the 12" bucket with my BH77 cuz I wasn't thinking about bucket sizes when I ordered my tractor and equipment or I probably would've opted for the 16" bucket. I'll probably buy one yet. But if I had it originally I would probably be getting the 12" bucket also. Both have their uses. I do have the quick change adapter and the BXpanded ripper tooth which is a game changer when you need to remove a stump completely.
To answer your question: Yup, I slide towards the hole/stump/etc. even with the 12" bucket. But at least it's not bending the hoe's stabilizers if they were locked in solid with the ground. Still, I'm going to fab up some larger pads with a little more bite because the ground I work in here is more on the softer side. It would help keep the pads from sinking in so much and stop a little more of the back sliding. Especially when digging on established turf. Another winter project for the to do list. 🤔
BX23S
2022 Kubota L3901 FEL, BH, GRAPPLE, PALLET FORK, SNOW PLOW and Hard Canopy
Sep 1, 2018
70
41
ID
I agree, the cone /\ of influence is 100' from the well head.
3,318
When I use my little B670 hoe, I roll the FEL bucket completely upside down so that when I plant it, all 4 edges bite the ground.
I also made oversize pads for the outriggers. Helped tremendously.
2nd pic shows the original pad in black.
Reactions: 6 users
