Bmyers
May 27, 2019
3,495
4,425
Southern Illinois
We continued to work on clearing ground at the farm. We had wonderful weather and got a lot accomplished. Took several bucket loads of firewood and dumped them into a pile for my sister and her husband that go camping a lot.
TiftTyson
2018 L2501 HST, LA 525 Loader, Landpride Rotary Cutter, Box Blades;Bush Hog Til
Mar 24, 2018
19
ATHENS, GA
Cut up two “blow over” trees for my in-laws and moved them using my grapple. I have a 60 inch Lanpride grapple for my L2501. It and the bucket get about equal time on my tractor. The grapple makes cutting trees and brush a more managable tasks. Beats loading everything by hand. I can go to bed without my back hurting after moving some pretty good size trees.
michigander
547
234
Northern Michigan
2 1/ hours on a mowing project yesterday my notes from 2018 show mowing 2 more times this fall and done if weather stays the same.
side note furnace was on past couple days lows into 40's
dlsmith
BX2230, LA211
Nov 15, 2018
1,302
919
Goshen, IN
I pulled the pivot pins out the the FEL bucket and cleaned up all the old grease, dirt and debris. Reassembled it and put about 1 1/2 pumps of good moly grease in each pin. It only took about 45 minutes, but looks better.
When I was done, I mowed my 3 acre yard.
Was a beautiful, cool day here in northern Indiana.
Bill Groom
B7100 HST
N.E. Ohio
Today I worked on the B7100, and buggered it up more than fixed it. I have developed a considerable oil leak at the front of the engine, and began looking into that. In the process, I noticed one of the new injectors was leaking slightly. In addressing the injector leak, I snapped the bypass line on the front injector. I was able to solder it back together, but I don't think that will last. I have been reading older threads on oil leaks on front of engine, and trying to determine how much more I want to put into this old girl. I have grown fond of her, but the new L2501 will be delivered before too long, and this just keeps costing me more money. Not sure when to pull the plug and call it quits.
Forvols
104
Hawkins county TN
Putting in 100ft of 12in DOT approved double wall drain pipe to route a year round spring that was cutting through the middle of my front yard to the robust creek that runs at the far side of my front yard. Northeast TN lots rocks and rock veins. Ended up having to use the natural drainage path of the spring. Hopefully I can up load some pictures.
7,075
Doing some late-summer lawn seeding where dirt work was done.
bearbait
Dec 9, 2011
4,145
897
New Glasgow Canada
Just changed the oil, grease, discovered I'll need to pick up a new air filter next week.
7,075
Seeding done. Talking rain Sunday and Monday. Good thing...
JeepinMaxx
BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
Mar 27, 2018
296
9
Columbia, CT
I know it's boring but I used my 3 point carryall to move a pallet with my BX2750D Snow Blower with the Mid mount PTO quick attach mount sub frame BX2751 to the driveway for the new owner to pick up later this week. I store all my implements on pallets these days...
B737
LX3310
Jun 9, 2019
2,022
2,205
you could also use bucket forks to pick that sucker up. I use them to place it on a rack
JeepinMaxx
Mar 27, 2018
296
9
Columbia, CT
Very nice! I have Titan clamp on bucket forks, unfortunately no inside racks!
JeepinMaxx
Mar 27, 2018
296
9
Columbia, CT
Used my improvised rake with a 2" receiver mount connected to my Heavy Hitch - worked out great!
johnjk
Apr 13, 2017
1,686
1,866
West Mansfield, OH
Leveled out where we trenches in drainage a few weeks back. Use the remaining dirt to fill in low spots.
TimP
B3000
Jan 16, 2012
64
Baltimore, MD. USA
Moodus CT? If so we are almost neighbors! 14" here in Columbia CT
Hi JeepinMaxx.
I like your LED work lights as well.
Can you please tell me what make/type of work light(s) you mounted on your tractor?
I mowed grass this past week at night using the crappy oem Halogen work lights and it made me realize I really need to mount some better lights on my tractor.
I liked the CREE 20", but wanted to compare it to what you have.
Thanks !
