Tughill Tom
B3200
Dec 23, 2013
1,380
1,843
Turin, NY
Dropped an old 28'X24' Garage and broke it apart with the BH and Thumb,
Good Times for sure! I Love tearing things down.
Now just waiting for the dumpsters to load up.
michigander
547
234
Northern Michigan
Trying to figure out how I can pull my lawn mower trailer behind the tractor , draw bar is too thick hole to big of course.
Buy something for the 3 point ? , need about 1/2" thick at most
michigander
547
234
Northern Michigan
Thank you :) I'm going outside to see what I need for a drop, quick measuring the Kubota is 6" higher than my Cub , below looks like will do the job if enough drop
https://www.amazon.com/dp/B016AX0L0...&pd_rd_r=b5c14598-b988-475c-b97e-37e59eaa4e49
And its on order due in Friday , I measured wrong 1st time this drop should work perfect :)
Bmyers
May 27, 2019
3,498
4,431
Southern Illinois
Worked on clearing more land at the farm.
Howling
BX2370
Feb 5, 2016
217
10
Ayer, MA
Finished up my trailer mover.
Built from broken quick-attach. Got local welder to repair the broken ear and weld on bar for the ball.
7,076
Did some grading, some quite steep.
As a big guy, didn’t realize a BX has a detachable steering wheel, does make the dismount a breeze....
Just kidding, the nut holding wheel on threaded off, so I had the wheel in my hand not attached to anything after I made a turn in the steep part!! [emoji15]
Doesn’t look like anything is broken, etc., just plain came apart. Easy enough to reassemble.
MOOTS
MX6000
Jun 27, 2019
2,189
2,716
Canton, Georgia
Might put a drop of loctite once you reassemble.
7,076
You know, I thought of a drop of blue loctite after the fact.
Might take it apart again, easy enough to do. Literally a 60 second job.
Sent from my QTASUN1 using Tapatalk
9,526
That's the special Nascar version BX! :D
4,405
We pulled some dead ash logs from over the hill up to the wood pile, easier to cut I can use the pole boom to lift them,and split there. A couple 18 inch logs 14 to 16 feet long low range 4wd and the little girl never grunted just up and away.
LwhiteAH64
L3901DT, LA525, LP RCF2060, LP BB1260, Yanmar 220 Diesel w/KK 60 Rotary Cutter
Jul 16, 2018
Dade City, Fl
Performed the initial 50 hour service on my L3901. Wasn't too terribly bad to do, even though I left my manual at work. So I just used the link provided from here and downloaded them to my laptop!! Pretty straight forward I thought.
edritchey
2021 Ferris IS800Z - 2025 New Holland WM75
Jul 19, 2014
1,126
840
Wellsville, PA
Cleaning up around the house and managed to bust one of the hoses off of the backhoe that goes to the thumb while digging out some stumps :eek: Also got a nice dent in the hood from a tree that broke off it just wasn't my day.
I wish I would have had one of our older machines around the house to use instead of my new MX LOL:p
It's finally getting some character.
johnjk
Apr 13, 2017
1,696
1,895
West Mansfield, OH
Had some drainage work done this past weekend. Did all the stone and backfill with the B. Would love to get one of those mini excavators IMG_4153.jpg IMG_4152.jpg IMG_4151.jpg IMG_4148.jpg IMG_4165.jpg
fruitcakesa
M 6040
Oct 26, 2010
856
270
Cavendish Vermont
Had a close call while working on the skid road.
While driving slowly through the hip deep fern cover, I ran over a pine stub that got wedged between the trans and the fuel tank:eek:
I stopped quickly after I heard it scraping/grinding on something below.
It was solidly wedged between the above area and the ground.
My chainsaw was out of fuel so I walked home in a rainstorm that suddenly started to get another saw.
Returned with saw and an ax, just in case, and got the offending stick out with not apparent damage to the tractor:p
I was then able to complete the skid road circuit so I can now access the trees in the way back areas.
special t
Pick up trucks of various makes vactor pipe cleaning truck, finn t75 hydroseeder
Aug 7, 2019
9
Scranton PA
While getting started on fixing grampas L245DT I noticed several wires disintegrating... trying to decide how deep i wanna go into bringing this beast back to life. Obvious sentimental value there and it would definitely be useful for loading dirt lifting pallets ect. The mower deck was dropped off to me shortly after grampa passed (6 years ago) but my uncle had the tractor itself until a few months ago when he decided to pass it on... broke down.
