raptorfan85
L2501, woodland mills wc46 chipper, 60" bolens finish mower, old cordwood saw
May 4, 2019
Richmond NH
Didn't do anything to or on my tractor, but did some thing for it. Built a lean to out of some wood I had lying around. Just in time for the rain too. Didn't come out half bad for someone with no carpentry skills.
edritchey
2021 Ferris IS800Z - 2025 New Holland WM75
Jul 19, 2014
1,124
831
Wellsville, PA
Looks like it will work fine.
johnjk
Apr 13, 2017
1,686
1,866
West Mansfield, OH
Finally got a break in the rain and broke the pressure washer out. Hey it really is Orange under all that caked on mud!
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
Moved a tone of stuff over the past few days. With forks on the three point I hauled out the brush hog on its skid, moved the finish mower and its skid, put a ton of crap on the forks and a skid. I have more to do we are scrapping a ton of stuff and moving everything from around the barn to get ready for a new coat of paint.
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
Moved a ton of stuff over the past few days. With forks on the three point I hauled out the brush hog on its skid, moved the finish mower and its skid, put a ton of crap on the forks and a skid. I have more to do we are scrapping a ton of stuff and moving everything from around the barn to get it ready for a new coat of paint.
SidecarFlip
Banned
562
Made the LAST 805 buck payment on my NH 450 Net / Twine round baler today. I buy all my equipment on quarterly payments, Kubota included. You can actually do monthly, quarterly, semi-annually or yearly payments. I like quarterly myself.
Missouribound
Jun 17, 2014
657
54
Missouri
Well it looks like you have some skills....
bucktail
Jun 13, 2016
1,276
198
MN
Sure does. It has a spring loaded lower platform that rolls the bale back a few feet. Had one that didn't. PITA. Long time ago.
Do you still have to weave back and forth to pack out the sides, or did they add a feature for that that too?
7,049
bucktail, you ask, "Do you still have to weave back and forth to pack out the sides?"
The reason you might have to weave back and forth to fill the bale chamber is because the windrows are too narrow. Wider and full windrows eliminates the need to zig-zag to get enough hay in the baler! The problem is in the one operating the rake!!
bucktail
Jun 13, 2016
1,276
198
MN
The only one I ever ran a vermeer 706C. It was 6 feet wide. We never had windrows that wide
2,428
Thanks, I guess you could call it a learn as you go process. YouTube is a great tool also lol.
If you want to see something built with no knowledge or skill search “shed of death” and enjoy the comments about it, it is evident that a structure can stand on good intentions only.
shootem604
Apr 23, 2018
874
British Columbia
Pulled out some old posts made of oil creosoted? railroad ties that were rotting and splitting after probably 40+ years in the ground. Then flattened some blackberries with the tractor - the thicket was over 6 feet tall and starting to take over the fenceline and harbouring mosquitos.
9,425
OH... the shed of death videos are so hard to watch! :eek:
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,829
2,236
Near Lancaster, PA, USA
Adjusted the 3PH feedback rod. It had been a minor irritation since buying the tractor last December. I knew to stop the control lever just short of all the way to keep it from bypassing. But one of my sons will be operating it soon and it's better to make it work as it should. Less than a 5 minute job. Makes no sense to have put it off for 7 months:eek:
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Got the back hoe home tonight,subframe and hydraulics installed. Fun part will be getting the hoe off the trailer.
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Was quite interesting gettin the crate off the trailer and the hoe out of the crate,but managed to get it.
SidecarFlip
Banned
562
Nice crate job if I don't say so myself. How did you get it off?
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Drug it to the back of the trailer with the tractor, the ran the toothbar into the crate as far as I could, took a ratchet strap and pulled it tight so I could pick it up over the lip of the trailer, then pulled it down the ramps. Little sketchy with no ballast on it but took it slow and it worked ok.
Was more fun picking the hoe up and getting jack stands under it in between the boards, the cutting it up with the chainsaw to get the crate out the way.
SidecarFlip
Banned
562
All depends on how wide the windrow is. I like full pickup width windrows if possible but it's not always the case so with a narrow windrow, yes, I move back and forth, not weave, more like hold and then cross and hold again, watching the bar graph on the computer screen as it pertains to how the bale chamber is filling.
Baler is 100% computer controlled, I just occupy the seat and do what the computer tells me to do. Bale density, and bale diameter are pre set values. I can control the wrap, twine or net depending on what I want by pressing a button on the keypad and I can also wrap a less than pre set diameter bale by the key pad as well.
It's like a video game console.
My sole job is to open the tailgate and eject the bale and watch for issues that do crop up like net spread or twine not starting correctly but I can over ride the automatic features and wrap manually in net or twine if I need to. Very seldom do that. Very seldom get out of the air conditioned cab actually.
Sure came a long way from my first round baler with manual twine wrap where you had to do the one thousand one, one thousand two thing.
I can run 44" or 48" or 52" or 54" over the edge net or sisal or poly twine in any of 5 different wrap sequences or a custom sequence of I want to. I usually use the default sequence.
Always had New Holland nay tools, bit then NH is popular here. The exception is my rake. I use an H&S rotary rake (pull behind) that I'll upgrade this fall to a Kubota pull behind rotary rake and I have a Kuhn tedder that I rarely use.
All my balers have real time continuous moisture readout and my 575 square baler has proprionic acid application as well. If the RM goes above 18%, the acid automatically kicks in and applies the correct amount of greensaver.
Fun but expensive hobby.
