Cfrazer
BX2670-1,FEL, BX5450, BBox, GS1548, RB1560, QH05, AI2 Forks, SS Curtis Cab
Jan 22, 2018
86
North Rose, NY, USA
Installed the sub soiler on the tractor and solved my drainage problem for awhile.
7,075
Did some spring grading on the driveway. Had ripper shanks down for a couple passes.
More touch-up to do.
Ollie helped until he got cold....
scratchypants
Godmanchester, Quebec
We'll be tearing down a section of our small, dilapidated barn, so took a couple of small steps in clearing it out: moved the grill from the barn and placed it on the deck; moved the cement mixer from the barn to behind the chicken coop.
fj40dave
Sep 24, 2009
425
257
Yelm, WA
Drilled 37 post holes 2' deep for a customer....first time using the post hole digger......worked pretty well. The coupling kept coming off the PTO for some reason....kind of a PITA. Only went thru two shear bolts.
I have a whole container of those now.
SidecarFlip
Banned
562
Changed the oil in both M's today. T6 in the 5-40 flavor. Filters too. Quick 7 gallons.
BXHoosier
BX24
Jan 21, 2018
497
591
Indiana
Moved my 12ftx12ft yard barn with my truck to make way for a new 24ftx24ft pole barn being built soon hopefully. Then, I used the BX to remove the concrete slab that was under the barn. Luckily, it was poured between 4 trees so it was already broken into 3 pieces.
SmallChange
B6200D
Jun 14, 2018
25
Port Deposit, MD
Moved about a cord of matted wet leaves out of the parking area with a landscape rake, and then dozed them over an embankment.
Moved about another cord of same out of the corner of our fenced area and pushed them into a pile of branches, compost, clippings, and previous years' leaves.
And hosed it down for the first time this year, having connected the outdoor water this morning. Let it dry in the breeze a while, put it into the barn (where I had just cleaned up a season's worth of neglect), and then sprayed a lot of the exposed and complicated metal with WD40.
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,506
530
Took my snowblower off, washed it and sprayed it with Krown to prevent any rust. Then gave the driveway a quick grading to fix all the gouges I made cutting the ice pack off with the loader when it first started to melt.
JeepinMaxx
BX2660, LA243 FEL, RCK54P-23BX MMM, BX2751 QH Subframe, BX2750D 50" Blower
Mar 27, 2018
296
9
Columbia, CT
dug my snowblower out of the shed (it's been there since I bought the tractor last year)
Put the blower, quick hitch, and PTO shafts on a pallet for the next potential owner
Orange4X4
L2350DT with loader , 52" Taylor Way , Ratchet Rake , Land Pride post hole
Aug 12, 2018
42
Concordia, MO
Replaced zirc fitting on rear of upper loader arm, cleaned and regreased
loader and found seal ring on bucket ram cracked & falling off.
Getting ready to change engine oil , filter & fuel filter.
Tomorrow go over brush mower clean & check for summer.
5,966
Worked on my new cab but afraid it’s going to get hung up in the Woods!
To me, it looks like the beginnings of a new "stealth turtle" disguise. You'll be able to sneak up on anyone.
mcgoo
32
CA
How did you oil spray it?
Sent from my SM-G955W using Tapatalk
3,679
JS5020... took me a moment... but that is just TOO FUNNY! :p
I just HAD to plagiarize it and send it to one of my buddies... LOLOLOL
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,506
530
Just with the spray can. I buy cans of it to use for a lubricant penetrating oil and rust preventative.
Then I bring my cars and trucks to the local Krown garage to have them sprayed.
