sjd50575
L4740 HSTC
Dec 1, 2015
19
Elk Mound, WI
Cleared the driveway. -11F tractor needed a boost, 10 years time for new battery finally I think. Any thoughts on going with wet vs agm vs gel?
mdhughes
L3901DT
Dec 10, 2014
1,364
1,136
Ste Geneveive county, MO
Split some wood today, it was 11F. The L3901DT started right up and idled itself up to around 1,200 RPMs and stayed there for a while.
This is the butt log from a tree I cut down yesterday, it is a little over 21" across.
I had a heck of a time getting the log splitter started. I used a propane torch to warm the block up and it finally started.
dalola
BX2380 w/FEL & Woods RM48 RFM, Yazoo/Kees Max2 ZTR
Jun 30, 2017
316
Got about 4" of snow yesterday, so of course I HAD to get the BX out to clear the driveway.....no way my F150 would make it out with 4" on the ground! :p
Good chance to play, actually, and use my urethane snow edge I put on the FEL. I must say, once again, the little BX was a pleasure. The R4's did better than expected, and the urethane worked great on the blacktop, with the FEL in float mode, scraped it off pretty clean. Sure beats the snow shovel & walk-behind snow blower. :cool:
I did notice the engine never really made it normal temp. It was about 15F yesterday, and I ran about an hour at 2-2500 rpm. I think I will make some kind of "wrap" to seal off the outer radiator air screen to see if that helps.
So, one more thing to love about my little BX! :)
billrigsby
Mar 17, 2015
1,039
217
Florissant CO USA 8213'
www.facebook.com
Greased the old tractor today and box bladed the driveway.
This weather is about crazy, first week of January and 50 degrees.
Only two measurable snowfalls the entire season and none of them
amounted to more than an inch. Last month Denver was going 65 days
straight with no measurable snowfall (66 was the record) until they got
a quarter inch at DIA, since then nothing.
Going to be a scary fire season, and an early one :eek:
8,654
Happened to drive in from Fort Collins that morning to DIA to catch a flight back to Arkansas :)
Sent from my SM-G920V using Tapatalk
8,654
WHEEEW, Them there blizzard conditions ! LOL :rolleyes:
They are here :p:p It becomes mass hysteria and panic if someone see's a snow flake :eek:
I saw my first snow of the season :D Too bad I didn't get to really see the area except for the trip to and from the airport. The rest of the time I was getting to work before daylight and leaving work after dark. Didn't see much other then street lights and porch lights. It got back up above freezing here. Supposed to have freezing rain tomorrow. Wished it would be all snow instead. I'm one of those crazy folks that likes massive amounts of snow :D
ItBmine
B2620, RTV-X1100C
Jan 21, 2014
1,506
530
Playing with everything right now in this wonderful minus 40*C/F weather. Did the main driveway with the Polaris (fast) and then all the turn around areas with the Kubota. Both start no problem in this cold. These two machines have never let me down.
Then hauling snow at night for the city in my Western Star under the snow blower.
5,853
Got 8 trees dropped and cut up today with high temp of 15. Finally got to use the new 42" pellet forks on the B2650 for the logs and brush. Worked great! All 8 trees done in approx 3.5 hours. That would've taken twice as long with my old BX23.
It was a great day. The dog sure was cold out there with me.
Blondie70
L2501DT('18)L2501('15)
Aug 6, 2016
267
Poplarville, MS
Nice looking firearms there, Lil Foot. Bet you had some fun shooting. I need to get out there and pop some caps myself....I think a camo towel would do the job ...ha ha ha ha ha
3,192
You're right, but not mine, actually. I just rotated the pic from Doctor481, post #3992.
Mike9
Kubota B6200
Oct 9, 2015
391
31
Ghent, NY
51 here today - a far cry from the sub zero weather we've been having. I haven't run the tractor for a while and the tank is full of fresh diesel. I plugged the block heater in for a couple of hours, gave it good glow and she started right up. Went for a 2 mile ride, hooked up the back blade, moved some snow then topped off the tank with Diesel 911.
Billdog350
Kubota L3710 HST,L2230A QT,forks,Takeuchi TB125, 60" Luck Now pto Snowblower
Jan 6, 2014
468
11
East Hampton, CT
Mike9, its advisable to only use the 911 IF you gel up...but you can use Power Systems fuel supplement (or other brands) to PREVENT it from gelling...and to lubricate the injectors and pump and so on.
911 can cause damage if used often or consistently. Its not designed to be used as a preventative.
