Chaentjens
Bx2680
May 13, 2017
58
moodus
I installed a water separator on my bx.
Made a bracket out of aluminum painted it and installed it on the upper 2 bolts for the loader.
Sent from my SM-N950U using Tapatalk
Sharryn
'15 B3350, LA534A Loader, Land Pride RTA1258 Tiller, BH77 Backhoe, Forks
Aug 31, 2015
88
Alexandria, PA USA
Nice job on the bucket holders! Heated buckets - only way to go. Love mine, especially here in Pennsylvania. I can remember when I was a kid, carrying two five-gallon buckets out every morning and evening for the horses. Certainly wouldn't do that at this age.
What auger do you have?
gcmiller
B2910, LA402 FEL, Caroni TC-910 91" finish mower, RTV900
Mar 13, 2017
105
Raleigh, NC
Tree cleanup pt1
I had an issue in the back of the property where cedar trees were growing at the base of my hardwoods and I also had a lot of trees that needed to be limbed and vines to rip out. I loaded the saws into the back of the RTV, cut everything, used the B2910 and a trailer to haul everything into one pile and then I borrowed a large chipper to turn a big pile of debris into a small pile of mulch. The chipper didn't like the vines or some of the small debris, so I used the FEL to haul that away - vines into the RTV to haul to the woods since they became one giant thorny tumble weed and the debris went straight to the woods with the FEL. I'll use the FEL to spread the mulch someday soon.
I'm including a before and after picture of a sycamore that had cedars at the base. I've only been in the house for two years and the previous owner neglected this section of the property; I'm finally getting to it.
kenmac
B26 with hyd. thumb and 4 in 1 loader bucket and EA Grapple, but not the wicked
Dec 14, 2015
92
9
Pell City, Al.
I piled and burned TONS of brush with my B26 and grapple. I apologize..............could not have happened. NO PICTURES!!!!
flyidaho
L 3301 HST
Feb 28, 2017
428
255
IDAHO
We got our first real dump of snow, 10" so far, with the usual deeper drifts, so I got to use my new 6' snow blade from QUICKATTACH on the L3301 (also new, last spring anyway). Compared to my old smaller Kubota the new bigger tractor really kicks butt, nothing like more weight and power!
4,402
I plugged the battery tender in does that count?
HEY Prof, what kind of hay burners you got there?
melvinhatcher
L3301HST, LA525FEL, 66" QA BUCKET, L8455CRUISE CONTROL KIT, WR LONG 3RD FUNCITIO
Feb 16, 2016
192
Edgewood Maryland
Ok, lets see some pictures.:):)
al m
Kubota b1750,60" mm,48" argo trend snowblower,5' grader blade
Jul 30, 2012
258
smiths falls on Canada
Snow is coming down steady,so I finally got the chains on my new to me b1750 and hooked up my 48" Argo trend 3th snowblower. My old two wheel drive b6100 got the job done,but wow does the extra hp and 4wd ever make a difference,tires not even loaded,no issues,will see what a heavy snow will do when it comes
Doing a little experiment with tensioning the tire chains,using chain and a turnbuckle on one wheel,a small ratchet strap on the other,will update results if there is interest
bearbait
Dec 9, 2011
4,149
901
New Glasgow Canada
Sure does Skeets, well only because I just did the same. Took a while but the Noco Genius trickle charger I bought brought my dead battery back from the dead. I was so impressed I bought a larger one today, now just have to get 2 more for the atv and lawn tractor.
5,991
cold rain here today so not much to do with the new tractor. So, I de-badged it ;) (removed about 15 caution stickers from hood, fenders and loader). Looks much better without all those damn caution stickers. Then gave it a nice coat of wax before it starts to get used regularly.
This is my second Kubota (BX23 for 12 years)...So, I don't need the caution sticker reminders. :p
Creature Meadow
Sep 19, 2016
1,065
140
Central North Carolina
Crazy warm here today for December even in eastern NC. So I washed Katie Kubota and then headed to deer land for a few hours in the stand.
8,717
All I got to do is sit on my new to me BH77 and pretend, the sub-frame is on order.
That sounds just like my luck with my loader :p:p Subframe is done, can hook it to the tractor. But the two hydraulic fittings I need are somewhere between Bejing China, and Conway Arkansas. Can't mount the subframe till I can do the hydraulic tie in :rolleyes:
So I'm stuck walking by it and petting the tractor and loader :(
al m
Jul 30, 2012
258
I skidded a entire ash tree,12" at the base through about a foot of snow,had to choke the base short a lift it with the three point,and there was plenty of pawing going on,got hung up on a corner ,but was impressed the little tractor handled it so well
prof.fate
75 L175, 14 toro timesaver, Landpride boxblade, countyline auger
Nov 9, 2017
155
Beaver, PA
got the ROPS mostly on..last 2 bolts are fighting me.
got the lights put together, brackets painted.
Hopefully tomorrow I can finish it all..I should have some help then.
My creative way of hoisting the ROPS alone...
