What am I missing, 540cc Briggs and Stratton engine running rich
ken erickson
Nov 21, 2010
1,413
2,631
Waupaca Wisconsin
As the title says , what am I missing in my repairs and diagnose of a 540cc Briggs and Stratton Intek overhead valve engine.
I recently made a trade with a neighbor that moved for his 2012 Craftsman YT3000 riding mower. I believe these mowers are also branded under the Husqvarna name.
The neighbor said the tractor would not restart after running for half hour or so, and he would need to remove the spark plug and wire brush the soot and fouling off.
After getting the tractor , indeed it was running very rich, would blow black smoke whenever you rapidly increased the throttle or at times hitting a slightly denser grass even though I just barely ran it before delving into it.
This is what I have checked or replaced.
Changed oil , new filter. not overfull and no smell of gas or diluted by gas.
new fuel filter
New air filter and checked intake and intake manifold for any obstructions
Replaced OEM Nikki carb with new Chinese clone carb
Checked choke cable, linkage and butterfly, choke butterfly opening completely and solidly.
Adjusted idle fuel/air mixture screw as per online instructions
Did not check float level as there are no adjustments. All plastic internal parts.
Checked valve lash
Installed and gapped new spark plug
Checked crankcase to intake manifold hose
Checked engine blow-by by pulling the oil filler tube cap while running and did not notice any excess blow-by. When shut engine down, a few wisps of vapor will come out of tube.
Checked ignition coil and gap to magnet in flywheel.
After all that I still have a rich condition but it is much better. I will describe now what the tractor runs like.
Starts and idles fine, goes to mid rpms fine and then to high rpms. No smoke even if rapid increase in rpm's.
Smells slightly rich but I do not see visible smoke with it stationary .
When I drove it and mowed , pretty rough yard as far as jostling around, but still level ground , occasionally and momentarily it will puff out black smoke. 1/2 hour of mowing my eyes were slightly burning from being rich. I could smell the rich condition. The mower cut grass, never stumbled or surged, responded to change in throttle and governor seemed to work if I hit thicker grass.
Since I have ran it what I have not done is pull new plug to see the color and if any noticeable fouling. Unlike before I changed out the carb and did the other items it will restart hot after 1/2 hour of running without issues.
One item I have not done is a compression check.
Any thoughts would be appreciated .
JimDeL
BX2380; 54" MMM; FEL w Pirahna bar; Ballast Box; BXpanded skid plate.
Aug 31, 2022
465
534
NE Ohio
Rich is too much fuel/not enough air. You didn't mention doing anything about the air cleaner - did you clean/replace it?
Other than that, leaning out the mixture, using the mixture screw, is about all you can do. BTW, are you sure your new TaiChi carb is really the right one?
JimDeL
Aug 31, 2022
465
534
NE Ohio
Another thought: Is the soot you see on the plugs from running rich, or sucking oil from either worn/broken rings, or worn valve guides?
ken erickson
Nov 21, 2010
1,413
2,631
Waupaca Wisconsin
As noted in my post, replaced air filter and checked for obstructions in intake parts. " New air filter and checked intake and intake manifold for any obstructions "
Other than the everything matching up with the outer shape, dimensions , and double checking my order and the engines it fits , no. I have not taken main jet out and measured as I have no idea of what size it should be.
ken erickson
Nov 21, 2010
1,413
2,631
Waupaca Wisconsin
That is a good question and reason I will check the compression. The old owner , straight up guy, gave me no impression that it consumed oil. I do not see any blue smoke, just soot black.
#40Fan
606
439
Vacuum operated fuel pump or is it gravity feed? If vacuum, where does the vacuum side of the pump go to? The intake (between carb and head) or to the crankcase?
ken erickson
Nov 21, 2010
1,413
2,631
Waupaca Wisconsin
Gravity fed, fuel line goes from tank, to filter, to shut off valve to carb
Caden
1979 B7100
Apr 16, 2026
245
122
Seems like those Chinese carbs are good enough but just never quite right like the original once was.
Maybe you could try to clean/ rebuild the original. New needle/seat etc.
Just a thought.
Your list of completed steps seems pretty comprehensive.
Workerbee
Zd21
Mar 1, 2020
375
252
MN
Ive dealt with an intek that a valve guide loosened and worked up. Its been so long ago (12-15 years) tho that I cant remember the symptoms. I do know that reknurling then seating the guide fixed the issue. Yould have to pull the heads to check.
4,193
I have no fantastic solution for you …. You may have to replace that carb one more time…. You may have gotten a bad clone…..
I own a YT3000 for 25+ years now and, for the money, it’s been a great little lawn tractor/mower.
The only “heavy” engine work it’s needed….. I thought it needed a new starter motor when the starter could no longer turn the engine over for starting….. But this turned out NOT to be the starter motor.
That B&S engine has an automatic (mechanically-operated by centrifugal force) compression-release inside it…and I had to replace that. Problem solved. Same old original starter motor still doing fine.
(It wasn’t too difficult a job… only about 4 beers worth.)
The only other real repair work was a spindle replacement after I ran-over a wire-tomato-cage hidden in the tall weeds.
Finally replaced the deck-belts after 20+ yrs of service.
Oil and filters occasionally. (cheap Walmart SuperTech)
BTW, most big-box/ store-brands are made by the same 2 or 3 mfr’s …. They make ALL of ’em…which are then badged according to the retail outlet. (Husqvarna, Deere, Cub Cadet, MTV, Murray, Poulan, YardBoy, Craftsman, Bolens, Troy-Built, etc etc …..the list goes on and on…. are ALL made by the same 3 mfr’s….(AYP, American Yard Products is the largest maker of almost half the brands)….many of them using interchangeable parts. The actual OEM/dedicated mfr’s…brands like Toro and Ariens and Kubota, Honda…. are very vew.
jaxs
B1750HST
Jun 22, 2023
1,072
809
I'm not going to say B&S never built Inteck engines that didn't have a pump but I've owned several and worked on several more all of which had pumps of one type or another. What you describe sure sounds like defective pump/ruptured diaphragm. I suggest you look again for a pump.
