want to add grapple
Papadiver
BX2380 FEL, MMM, 3rd Valve, Grapple
Feb 10, 2019
97
70
WV
Having everything a one handed operation, on the joystick is a pleasure to use. I Grapple a LOT of logs, branches, railroad Ties, Lumber etc.
Do you have any pictures of your grapple? In use pictures?
6,902
Couldn't another valve connected to the power beyond provide the function he is looking for to operate the grapple?
Sure, but unless it's electric you'd have to remove your hand from the joystick to operate the grapple, not very convenient.
Unless that valve has a joystick switch. ;)
blenderbender
B3000
Mar 5, 2016
58
Eastern Ohio
Okay.... thanks to all your input(s) I've purchased a 3rd function kit for the FEL.
Now I'd like to add a multiplier to my single set of rear remotes. Cost is again a big concern for me. I've located a switch controlled kit ($425), a manual multiplier (approx. $275-$290) depending on my fitting needs, and find myself wondering if there is any cheaper, yes I'm frugal, way to accomplish this. I have a hydraulic top link and would like to also be able to angle a back blade in the near future. Sticking my hand out the rear window to throw the lever on the manual one would not be a big issue as the rear remotes are within easy reach.
bearskinner
Sep 1, 2014
926
241
N. Idaho
I find I use my Grapple more than any other implement. I’m on heavily forested land, so there’s always spring cleanup. I also get firewood by the semi load, I can Grapple the logs over to the sawbuck right in front of the wood shed, which is a huge time and back saver.
I unloaded two large piles of (90 lbs each) Ties and stacked ( using the Grapple the whole way) them to make safe target backstops. Great for hauling fencing, Posts, etc.
Also a fun event from the PNW Kubota Tractor Games, stacking tires and wooden blocks, using the grapple
5,789
Hey Bearskinner, I haven't got my new glasses yet. Can you possibly increase the size of your artwork, so I can admire it?:D:D
It kinda looks like you're having fun, but I'm not sure.
War Eagle
2012 B3000HSDC and Allis Chalmer 5020
Jan 15, 2017
103
22
Nampa, Idaho
Any pictures of your third function valve install?
Are you happy with it or would you have preferred to do something different on your install?
blenderbender
B3000
Mar 5, 2016
58
Eastern Ohio
Unfortunately I have been up to my ears in other projects with a higher priority and I likely won't get to it till late summer or fall. I do know that it's going to be a challenge for me as there is no real nice spot to mount the block and there's going to be lots of hydraulic plumbing in tight spots which I ain't looking forward to. Assuming I get er done.... I'll post the results here. Thanks for asking!
War Eagle
Jan 15, 2017
103
22
Nampa, Idaho
Ya, there isn't a lot of real estate to choose from to locate your 3rd function valve on the B3000. I mounted mine on the FEL arm. With the cab on my tractor there just isn't any convenient place to put a 3rd function valve block so that there is easy access and minimal interference with other things on the tractor. I think compact tractor probably implies limited space to add things to your tractor.
Anyway the solution I came up with took a fair amount of head scratching and the deciding factor for me directly related to being able to hook up hoses and service access for potential leak fixing etc.
My install has worked really well for me and I yet to have any leaks to fix.
Here are a couple of pics.
blenderbender
B3000
Mar 5, 2016
58
Eastern Ohio
Thanks for the pics, I'll definitely be zooming in on them. Obviously I haven't got around to the project yet...... ya know.... Life and all. But I have another tractor available come Spring so I should be able to sideline the B3000 and get to the install.
Bmyers
May 27, 2019
3,317
3,907
Southern Illinois
I like that grill guard.
flogler
2017 BX23s
Dec 18, 2019
55
Debary, FL. USA
I too would like a grapple for my BX23S. It has the 3rd function kit already installed. I just can't see paying that much for the grapple. Any suggestions-I know the after market china ones are built different but price is a bigger concern vs getting bent up.
War Eagle
Jan 15, 2017
103
22
Nampa, Idaho
With a BX23S you're going to be limited to probably a 48" grapple and the lightest one you can find. At 450 lb. ( I don't think you'll find one lighter) look at https://www.palletforks.com/skid-steers/grapples-and-rakes/grapple-buckets/48-inch-grapple-bucket-attachment-for-skid-steer/112300.html?lang=default
MTL makes grapples and here is a single clam shell model at 350 pounds.
https://www.mtlattachments.com/atta...pple-hydraulic-brush-grapple-attachment-wk53p
Here is a 60" double clam shell model at 390 pounds.
https://www.mtlattachments.com/tractor-attachments/new-compact-vertical-root-grapple
Kennyd4110
Vendor Member
Sep 7, 2013
1,250
467
Westminster, MD
www.boltonhooks.com
There are MANY lighter grapples to be had..just not from CHINA. They add more steel rather than use better engineering.
A 450lb grapple on a BX would be all but useless.
