Upgrading to B model.
Caden
1979 B7100
Apr 16, 2026
375
214
primarily looking at B2601 and B2301. But I’m wondering about the B3030 and B3200.
This thread went off course. As they usually do.
@Bald1 , you gave a list of 4 tractors you were considering, and yet didn't expect that people who own the 4 such tractors would give you buying advise?
As I see it, its a pretty ambiguous thread title and question, so saying people de-railed your thread is kinda out of left field IMHO, since they are all just trying to help you make an informed decision on the topic you brought up. :unsure:
Bald1
Bx1859
Oct 12, 2026
25
10
Western NY
I asked directly about anyone having experience with a 4’ brush hog mainly on the biggest of the B series. I’m buying a B series with a BH. Yet guys are talking about skid steers and mini excavators. I understand thread drift. Happens all the time on the gun forums. Guess we can just kill this one.
Shawn T. W
Dec 9, 2024
868
1,576
SW Missouri Ozarks
Sometimes we don't think of all the options ...
If back when I was looking for a BH ... If someone had told me to consider a Mini-X ... I definitely would have looked at that, and probably would have bought one over my little SCUT TLB! (And then bought a bigger tractor for tractor work ...)
I only bought the SCUT TLB as it was all I could find within a 100 miles of me ... This was March of 2022, not much available in tractors or TLB's then, not sure of the Mini-X availability back then, as I didn't think to look ... But I'm heavily invested now in my SCUT TLB, so I'm keeping it, and making do without buying a Mini-X ...
JasonW
907
614
Al
A guy asked a question then doesn’t like the opinions that were offered…
If a 4’ cutter works with your BX why wouldn’t it work on a B series? I can run my 4’ cutter on my M6040 but that wouldn’t make much sense.
I brought up older excavators due to cost. I recently bought a KX040 that cost less than a B series with loader and backhoe. And you can get a larger one even cheaper. Since you wouldn’t have to haul it anywhere that’s what I recommended.
Bald1
Bx1859
Oct 12, 2026
25
10
Western NY
it would run and operate just fine. My concerns were, does 3 inches narrower than tracks on back matter. I wondered if tall grass got matted down and didn’t get cut on next pass….. as to opinions offered. That’s what forums are for. But when opinions don’t address a pretty direct question it’s not much help.
Bald1
Bx1859
Oct 12, 2026
25
10
Western NY
Caden
1979 B7100
Apr 16, 2026
375
214
Title of thread was “ upgrading to a B”. Nothing ambiguous about that.
Well, if you had titled it "Can I run a 4ft mower on B3200" , you would have gotten a focused response, rather than getting buying advise that goes with the current tittle of "Upgrading to a B".
Shawn T. W
Dec 9, 2024
868
1,576
SW Missouri Ozarks
Well ... Kinda sorta along the same lines ...
I originally got a so called 4' brush hog with my 25 HP SCUT, which actually is 4' outside to outside, cut is 44" ... after I put on 3" spacers my SCUT rear tires are 50" wide outside to outside ... I had to mow with one set of tires on the previous cut area ... Especially on a turn, as it has quite a tail swing!
I ended up the next year trading it the next year for a 5' version which has a 56" cut worked fine, but required me keeping something in the bucket for front ballast weight, as it was obviously a foot longer, and also heavier, so it was a bit light on the steering at times ...
With all that said ... I then bought another tractor, but didn't have the cash to buy a mower for it, so put the 5' brush hog behind it as I was eager to mow with my much more comfortable larger tires, and A/C ... It worked just fine! IIRC tires are 68" wide ...
It's just the nature of the brush hog design, you gotta run over the grass before you cut it ... My guess is that using a 4' brush hog behind a B, inorder to have a slight overlap, you will want to have one side of the tires on at least part, if not all of previous pass of cut grass ...
Do you know if your 4' brush hog actually cuts 4', or is it less like my Bush Hog Brand is?
Bald1
Bx1859
Oct 12, 2026
25
10
Western NY
ok, I check with you before my next post. Not looking to get into a pissing match over this. Have a nice day.
Oliver
L2501, JD 3520
Feb 2, 2011
544
137
Preston County, WV
My situation somewhat mirrors Bald's. When I originally bought the property I'm on now it consisted of 49 acres with about 1.5 cleared which I left as a little meadow. I had another 2 acres cleared for my home site, the remaining 45.5 acres were wooded which we cut some walking / atv trails through.
I wanted a tractor with a loader and mower deck to maintain the 700' drive, snow removal, moving material, mowing the lawn around the house and also the meadow a couple of times a year. I looked at a BX but was concerned about its limited ground clearance so decided on a B7500 (similar to B2301), loader with 4' bucket, 54" mid mount deck, and 6' rear blade. I was saving for a 4' rotary cutter to buy later.
With this combo I was able to accomplished all my tasks in fact the MMM raised all the way up was able to cut the tall grass/weeds of the meadow just fine so I never bought the cutter. This little tractor just with a strap around the bucket moved and stacked a few hundred 11' pine logs. It could only lift the very largest ones about a foot though. It mowed the lawn, cleared snow, spread gravel, and did various other chores, it was all the tractor I needed.
I was considering buying forks or even adding a 3rd function and grapple to it when a neighbor's larger property came up for sale. After I added it to what I had, I felt I did need a larger tractor because there was a lot more to mow and a lot more wooded trails to maintain. My whole point here is don't under estimate what a 21hp tractor with a loader, mower, and rear blade can accomplish.
I have a grapple for my current tractor which is extremely useful on wooded property, had I kept the B7500 I'd have bought a small one for it because it's probably used more than anything.
Bald1
Bx1859
Oct 12, 2026
25
10
Western NY
I’ve never measured it. But I’d guess it’s the same as yours. I’m lucky in that most of my brush hogging will actually be light brush as opposed to grass. And it’d only be a couple acres in a pond area with an old grain house
Thanks for the insight. I agree that people underestimate what the smaller factors will do. I’d love to find one with a MMM as well. I (my wife) currently mow with my BX.
trikepilot
B2620HSD LA364/BH65 48SQ Bush Hog LP FDR1660 LP RB1560 B2672 42in forks LP1266
Jul 18, 2020
208
287
Hardy, VA
I'd love to find one with a MMM as well. I (my wife) currently mow with my BX.
My $0.02 from a happy B owner who, like you, prefers one machine to do it all full well knowing that compromises will be made.
I think you are on the right track. I have done some really big jobs with my BH-on-a-B - I just go slowly. The thumb you mentioned AND a root ripper are worthy investments!
The one thing I have seen you mention that I might get you to rethink is the MMM. I think you should look into the relative merits of a good 60in 3pt finish mower. I mow with one of these beasts and it does a great job with the added advantage that it is EXPONENTIALLY easier to swap on/off. Imagine you have the MMM on and you decide to go use pretty much any other rear attachment much less the BH? It is kinda inconvenient to have the MMM on for these uses and taking the MMM on/off is WAY harder than a rear FM.
Other than that... get what you want that fits in your budget - keyboard jockeys be damned!
Oliver
L2501, JD 3520
Feb 2, 2011
544
137
Preston County, WV
TBH I didn't find the mmm difficult to put on and off and the tractor was much more maneuverable with it than with a pull behind finish mower or brush hog. I will say I put mine on and off in a garage with concrete floor it would be more difficult if out on the yard or on a gravel driveway.
Bald1
Bx1859
Oct 12, 2026
25
10
Western NY
thanks for input. As far as finish mowing I’m downsizing big time. I’ll have less than an acre to mow. I have the mmm on my BX. The swap is easy but I assume b will be harder due to size and weight. Only mowing less than an acre. My wife wants a zero turn so that might happen
Bald1
Bx1859
Oct 12, 2026
25
10
Western NY
concrete floor definitely helps
fmgsr
Kubota, LX2620 - Kubota BX2380 (retired)
Dec 19, 2018
100
51
PA
I had a BX 2380, after 8 years, I wanted more power. I was set on a B,
until I sat on one at the dealer, and it felt very similar to my BX. There
was a L on one side of it, and a LX2520 on the other. As soon as I sat on
the LX I was sold. I am very happy and satisfied. Go to the dealer.
Bald1
Bx1859
Oct 12, 2026
25
10
Western NY
Yeah I get that. I stop by dealer once in a while to browse. The L is a solid choice. Much heavier but also much more expensive. Because I’m getting ready to break ground on our new house. So I keep cost in mind.
PaulL
B2601, MX5200.
Jul 17, 2017
2,812
1,803
NZ
I find swapping to the MMM on my B2601 dramatically easier than it was on my BX. There's more clearance, and it's a drive over deck. Not the BX drive over, with a funky driveshaft attach that is finicky. Just literally a deck you can drive over, so you don't have to pull it out.
Refer my video I post every now and then on taking it on and off.
Having said that, the larger B has a different system, because it's a ground contact deck not a suspended deck.
Kubota B2601 MMM deck removal and reattach
Bald1
Bx1859
Oct 12, 2026
25
10
Western NY
lol, so I’m not the only who shakes his head at the BX driveshaft. It’s difficult to reach up in there to connect it. The bigger the operator the harder it is.
