Upgrading to B model.
Bald1
Bx1859
Oct 12, 2026
Western NY
I’m upgrading to a B model from my 1850. Looking at used models with a backhoe and loader. Building a new home on 50ac in WVa next year. I have more than enough projects and maintenance to do that justify the BH. I was primarily looking at B2601 and B2301. But I’m wondering about the B3030 and B3200. I want to keep my 4’ brush hog, and box scraper. I know these will work on the 2600 and 2300. Any experience here with 4’ implements on the two slightly larger tractors? Thanks.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
4,024
2,481
WestTn/NoMs
Most of the B's are a smidge over 48" wide at minimum track, so 4' implements won't quite cover the tracks. You could start with them and keep an out for 5' ones.
If this is a hilly place, you may want a wider track.
trikepilot
B2620HSD LA364/BH65 48SQ Bush Hog LP FDR1660 LP RB1560 B2672 42in forks LP1266
Jul 18, 2020
206
280
Hardy, VA
I have a B2620 and I use it in VA not far from WV. In these hilly forested areas, I find it meets the sweet spot between capability and nimbleness. It has done everything I ask of it but I do know my limitations and on anything approaching the upper limits of capacity, I just go slow and careful.
I would liquidate the 4ft implements when you get rid of the BX. The OEM width of my rear tires is right at 52 inches. A 48in implement won't cover your wheel tracks. I have all 5ft implements and they work great and don't tax the B2620 too much. I also have the OEM frame mounted backhoe (BH66) and it has been wonderful. I too would advise adding rear wheel spacers if you are in hilly country as they add a good bit of stability. Otherwise you are gonna really enjoy your new Kubota
Caden
1979 B7100
Apr 16, 2026
349
196
I sometimes run a B3300SU for my neighbor, which should be very similar to the B3200 you mentioned, I think, with the exception the 3200 has a mid pto.
I wouldn't drag anything less than 5 foot ideally. Brush hog, you could get by with a 4ft.
As a side note, I hate that 3300, I would rather use almost any other model/brand than that. Cheap and sloppy IMHO.
Bald1
Bx1859
Oct 12, 2026
Western NY
If I go the 2601 or 2301 route I’ll definitely keep 4’ box blade and brush hog. I’m not worried about less than an inch on each side. It was mainly the larger one. I’ve got my eye on a low hr b3030.
