The above statement is precisely why I bought the L2501 If I needed a larger Tractor it would be a pre emission used machine.Most of the smaller tractor emission issues is user related. If you idle it around or only use the RPM you think you need you are doing the tractor a disservice. Same goes for letting it idle for extended periods. Run it at the recommended RPM and you will be fine.
