1/ Found this odd valve thingy while greasing underneath. Can't see anything about it in the WSM. The pin is loose and not oily. It's the only thing not painted.
What is it?
2/ The new hydraulic filter is bigger than the original and gets in the way of the hose even more. i'm thinking I should re-route the hose above the 2 steel lines.
Is that a bad idea?
When I unscrew the fitting on the main block is it going to piss out fluid like crazy?
Thanks
What is it?
Is that a bad idea?
Thanks
