TRAILER SAFETY CHAINS
3,396
All I can think to say at this point in this thread, is...
I buy a lottery ticked once in a while, only because I realize if I don't buy ONE ticket, I have no chance of winning...one ticket, 100 percent change from nothing to something.
Yes, this relates to this thread if you think about it... :ROFLMAO:
Shadetree605
kubota b2100
May 1, 2022
228
114
north little rock, ar
I cross my chains when i pull any trailer, will it keep the trailer off the ground if it comes unhooked ?, maybe..maybe not ?, from what i personally have noticed is no..it will not keep it off the ground if chains are crossed..or straight. unless the chains are so short, that would stop the front of trailer from hitting the pavement ?, then no..it will not stop it. same goes for the safety chains being too short, if this is the case, you will not be able to make sharp turns without bending tailer tounge or breaking the safety chains. i do know for a 100% fact, safety chains either crossed or straight ?, WILL NOT KEEP THE TOUNGE FROM DROPPING ALL THE WAY DOWN ONCE THE TRAILER TOUNGE CATCHES TOW TRUCK HITCH SLACK !. now..if you are pulling forward down a road, load weight on trailer tounge ?, then yes..it will craddle it, BUT !!!, once the trailer's tounge catches up to the towing truck ?, then yes...the safety chains WILL NOT craddle the trailer tounge, and stop it from dropping all the way to the pavement. safety chains are not a solve all, keep everyone safe..THEY ARE A BACK UP SAFETY FEATURE..THIS..AND THIS ONLY. If you hook the trailer up correctly ?, then this means the less you need to worry about
Last summer i had my sister pull my jet ski, while i pulled my small camper, before we left the camp ground, i hooked up my jet ski to her truck, checked all latches, safety chains, everything, we got back to my house, and she told me when i was getting out of my truck..she heard noises while we were on the freeway home coming from the back of her truck ?, hmm..i walked around to the back of her truck to unhook my jet ski, sure as shit..the coupler was sitting on top of the hitch ball..but not latched down on it ?..how the heck that happened i have no idea ??..i always lift up on trailer tounge or use the jack to lift tounge up to make sure its attached solid on ball !!, somehow in this case, the latch got loose, and road the whole 1 1/2 hrs just sitting on the hitch ball ??..I HAVE NO IDEA HOW THIS TOOK PLACE ??!..BUT THANK THE LORD IT NEVER FELL OFF THE BALL ?!..THIS JET SKI IS LIKE BRAND NEW, 20 HRS ON IT ( 2015 YAMAHA WAVERUNNER ), not a scratch on it ( at that time ). soo..all you folks that feel the need to cross..or not cross your safety chains ?..IT DOES NOT MATTER...IF YOU DO NOT MAKE SURE THE LATCH TO THE BALL IS CONNECTED CORRECTLY !..please...PLEASE..CHECK..DOUBLE CHECK...TRIPPLE CHECK..MAKE SURE YOUR LATCHES ARE SUCCURED TO THE BALL !.
Flintknapper
L2350DT
May 3, 2022
2,024
2,578
Deep East Texas
In your analogy you expect NOT to win. With crossing the chains....the inference *by experts* is that it WILL catch and cradle the trailer tongue (patently untrue in many cases).
There are no safety concerns with the lottery ticket. Crossing chains in 'hopes' of catching an unattached trailer tongue ( giving you that one in ten thousand 'chance') and 'feeling good about it' is about as useful as buying that lottery ticket. States do not 'require' you to buy a lottery ticket, but some DO require you to cross your chains (despite it being pure folly in most set ups).
Yes: .0000000000 is no chance
But: 00000000001 is so close to no chance as not to be distinguishable.
Yet folks allow themselves to be forced to comply and conform to nearly anything these days. Many are easily fooled by the 'experts' or worse 'themselves'.
The real issue is the trailer tongue coming loose/dislodged to begin with. THAT is what should be addressed. By the time you need 'safety chains' things have gone horribly wrong and crossed or not....the best you can hope for is that the trailer stays with the vehicle in one form or another.
3,396
NO, not quite.
I realize the chances of winning are nearly zero, BUT my chances of winning by buying the lottery ticket improved by 100 percent when I bought the ticket.
Same with crossing chains. If crossing chains MIGHT help in a worst case event, why not cross them? Like with the lottery ticket, they can only help when crossed, if crossing them helps at all.
Can't win a lottery prize if you don't buy a ticket. Can't expect crossed chains to help you if you don't cross them. In both cases, the chances of winning the lottery or needing the help crossed chains MIGHT give you, are slim.
But you never know...
Flintknapper
L2350DT
May 3, 2022
2,024
2,578
Deep East Texas
NO, not quite.
100% of .00000000001 is .00000000001!
Do whatever makes you feel 'good'. ;)
3,396
Yes, but the reality is 100 Percent chance over no chance is still HUGE. Regardless of how small the chance is. I think you miss this point.
Just playing with numbers I suppose. But WHY NOT maximize one's chances, however slight? Something versus nothing is a huge difference.
Some choose to ignore the probabilities...I accept them for what they are. AND play them to my benefit when I can.
Flintknapper
L2350DT
May 3, 2022
2,024
2,578
Deep East Texas
Fooling yourself and conforming to regulations that do the same.
A 100% 'chance' of realizing a .0000000001 'probability'. You'll never see that supposed benefit.
3,396
But the reality is still there. Splitting hairs of course. But why not maximize the odds?
Whatever the odds might be. Of course, one may not do that just to prove a point to himself...but people do win the lottery...and making a small difference in the safety chain hook up might also make the difference once. Probably not, but MAYBE.
What's the big deal anyway? It is all about maybe or maybe not. If maybe exists, then why not try to compensate for it, even a little. Is it a big deal to cross safety chains? Not in my world...
Carrying the thought further, why even use safety chains? Almost never needed right? Your argument can be carried as far as you like, as can mine...but the bottom line is your either do your best to minimize the odds of something bad happening, or you decide not to worry about it and hope for the best.
Flintknapper
L2350DT
May 3, 2022
2,024
2,578
Deep East Texas
There is no 'harm' in it of course. When performed as you elect to do (personal choice)....fine. When 'required by LAW' under penalty of fines, then NO.
Would you play the lottery if you were forced to by law? Knowing full well the 'return' (winning the jackpot) would be about 146 million to one! But if caught not playing the lottery you would be fined 100%.
You would probably question the value of that....while the State is arguing (yeah but you MIGHT win).
Does probability take on a different meaning then?
That is my point. I couldn't care less what people CHOOSE to do with safety chains (cross them or not). Just hope they understand its a nearly fruitless (feel good) endeavor.
5,187
We tried "hope and chains" once. 😂
As I recall, it did not accomplish much!
5,580
Yeah I know old thread, but it got me thinking , scary I know. If you are in Pa this is the law Part 18
§ 4905. Safety requirements for towed vehicles.
(d) Safety chains.--
Whenever two vehicles are connected by a ball-and-socket type hitch, or pintle hook without a locking device, they shall also be connected by two safety chains of equal length, each safety chain having an ultimate strength at least equal to the gross weight of the towed vehicles. The safety chains shall be crossed and connected to the towed and towing vehicle and to the tow bar so as to prevent the tow bar from dropping to the ground in the event the tow bar fails or becomes disconnected. The safety chains shall have no more slack than is necessary to permit proper turning.
11,757
I made this point way back in this thread, but Montana has at least 290 mountain passes and yet state law doesn't require any chains on a trailer with a GVWR of 3,000lb or more. What is required on trailers with a GVWR of 3,000lb or more are brakes on each axle and a system capable of activating those breaks for at least 15 minutes after the trailer and tow vehicle become separated. That said, I've yet to buy a trailer that didn't come with chains, but then again, trailer manufacturers don't typically build trailers for sales in a specific state.
By the way, a mountain pass is defined as a navigable route through a mountain range or over a ridge. How many of those does PA have compared to Montana? As for state and federal laws, they are not always based on facts, statistics or other meaningful data. Sometimes they're arbitrary, or specifically aimed at generating income, or simply erroneous from the get go.
I currently have six trailers including a 30ft gooseneck trailer with dual tandem axles, a 16ft tandem axle dump trailer, a 10ft single axle dump trailer, an aluminum boat trailer for a 21ft boat, an aluminum 10ft single axle trailer and a tandem axle trailer that used to be under a camper. They all have chains or cables and I connect them to the tow vehicle despite not needing to by state law. However, I make sure that the chains or cables can't drag on the road (fire hazard) but I don't cross them. All of the trailers have brakes with the exception of the single axle aluminum trailer. That one has chains, and by state law one of the chains has to be connected to the tow vehicle since it has no brakes and a GVWR of less than 3,000lb.
lynnmor
B2601-1
May 3, 2021
1,799
1,605
Red Lion
That is impossible on many combinations, but the nonsense goes on forever.
5,580
Well McMxi you start at the Cumberland gap in Cumberland Md,, and go west,, and you will travel there the Appalachia mountain chain which runs from Va through Pa up in to NY, not as high but older than your neck of the woods for sure. And yes we have the tail of the dragon and other places going over and down the other side where you can almost see the back end of your wagon if you look out the window. And then toward the middle of the keystone you reach the Appalachian plain, mostly moraine from the glaciers that cut the valleys and ridges, until you get to the western part of the state around Da Burgh and north toward Erie. The cuts, ridges or passes may not be as high or as grandiose are yours, but they have killed many a good driver Oh and all my chains are crossed too ;)
11,757
Unfortunately, Montana is ranked as the most dangerous state to drive with the most road deaths per capita, but the reason is more nuanced than simply topography. If you go off the road up here to avoid a deer, elk, bear or moose you can end up in real trouble. A good friend who was a State Trooper for 20 years in Eastern MT told me never to leave the road for anything smaller than an elk or moose. It's instinctive to steer away from trouble, but up here there are so many places where leaving the road will kill you.
"Many of the most dangerous states to drive in have stretches of rural highways through mountain passes, including Montana, New Mexico, Wyoming and Arizona. These roads become extremely treacherous during winter, where snow, ice and deadly speed limits often mix with tragic results. "
BAP
Dec 31, 2012
3,179
1,295
Sounds like it’s more Driver Stupidity than roads if you aren’t smart enough to slow down for road conditions.
11,757
Impaired driving, inattentive driving (e.g. texting), and general incompetence are certainly the major causes of accidents up here or anywhere for that matter, but what is a safe speed on a road with a 70mph speed limit given the wildlife up here? Bad things can happen even when you do everything right.
Since this thread is about trailers, I would guess that the major cause of trailer related accidents is ignorance, incompetence and either poorly maintained or inadequate equipment or simply the wrong equipment. I have never had a trailer separate from the tow vehicle but I know of two people that have experienced it. I have good equipment which includes B&W hitches, the proper receivers rated for the loads hauled, Demco couplers or similar, a Tekonsha trailer brake controller in the '02 F-250 and a factory TBC in the F-450, etc.
I take care of my vehicles and trailers and take towing very seriously. I'll be towing the 30ft gooseneck 200 miles this weekend loaded up with an LMTV M1078 that according to spec sheets weighs 17,000lb. Matson who shipped it from Hawaii to Tacoma listed the weight as 14,500lb but I don't know if they figured that out or whether my friend reported that weight to them. I do wish that we had a scale in the area to get on, but regardless, I'll take the time to position the truck on the trailer and to chain it down properly in addition to checking the lug nuts and air pressure on the trailer. I'll also be on high alert the entire time and will give myself plenty of time to make the trip without undue stress. The 200 mile trip home with an empty trailer and a bunch of cash in my pocket will be relaxing.
